Question about Birds
Looking for a blue bird with a blue head feathers and red eyes
How to get rid of lice on small birds
No idea of your country but a 20Second google search revealed this;
To remove lice, it is recommended to use a mild pet insecticide, such as "Nuvan." After spraying the plumage, wait for 2 - 3 minutes and then gently ruffle the feathers over a white tray or plastic sheet to collect the lice which fall from the feathers.
I found that one great way to remove lice and mites from your birds is to sprinkle Sevin Garden dust under their wings and tail, and on the back. Check the birds the next day and if there are still lice present, repeat the process, as needed. I found Sevin dust [active ingredient: Carbaryl (1-napthyl N-methylcarbamate)] equally effective in getting rid of red mites.
Avian Insect Liquidator is another way to get rid of mites, lice and other insects in the birds' environment. This all-purpose insecticide from Vetafarm contains a water-based insecticide that is harmless to birds but effective against insects.
Prevention:
Sanitize and treat the birds' environment (cages, perches, aviaries, nesting areas, etc.). Secondly, allow your birds to bathe daily. Most birds enjoy doing so and if you provide them with a shallow clean dish, they will usually be happy to bathe without encouragement. Some birds like to be misted, or even sprayed. Sprinkling Sevin dust underneath nest bowls and around nests will eliminate all kinds of insects.
Aug 06, 2017 | Birds
Some of my chickens have feathers missing on their necks and sores are appearing as little red spots
bird lice infestation
call a vet for a proper diagnosis and treatment plan
Jun 23, 2017 | Cars & Trucks
A black head small Australian bird with a white patch on both sides of its head with a red beak
check the bird identification pictures but it sould like a black head finch
Mar 10, 2017 | Cars & Trucks
Why have my cockatiels lost most all of there feathers? trying to find out what be causeing it .. I just got them ..
My understanding is these birds get used to one person and when that person is no longer around they pluck their feathers out. A friend of mine had one and when he passed away the bird took out all his feathers. My son took the bird over and in two years the bird would get a few feathers then keep losing them. He did not fully recover in two years.
Dec 22, 2014 | Cars & Trucks
Removing chicken feather commercially without human inthe process?
This generally involves the use of a "plucking machine". After the chicken runs through the kill line, it is submerged into a hot bath of water in order to losten the feathers. The bird is then taken through a plucking machine which has rows of rubber "fingers" spinning on each side which pulls the wet feathers from the body of the bird. A constant stream of water washes the feathers down into a collecting pit for disposal.
Dec 17, 2011 | Computers & Internet
Hoe to take head off of tripod
The heS IA MOUNTED ON THE BASE WITH A 3/8" SXREW STUD (BASE) AND FMEAL (HEAD). i IS HELD IN PLACE BY TGHREE SCREWS in the baSE. rAISE TRIPOD CENTER COLUMN A FEW INCHES, loodrn the three set screws, then twist head counter-clockwise(if looking at top from birds=eye view.
May 05, 2011 | Bogen Manfrotto 475B Black Tripod 475 USA
Remove 3130 head from 3021 tripod
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Apr 23, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
How do I reboot the printer to factory settings?
>press print photos and red eye removal buttons at the same time it will say enter special key combo
>press red eye removal then print photos then back to red eye removal successively
>then use the blue button to look for reset menu then press ok
>then press the blue button again to look for semi full reset then press ok
Sep 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Birds Logo
64 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
