Question about Jabra BT125 Headset
Jabra bluetooth won't work
Stop working
Volume does not adjust, when pressing the volume button up or down, jabra bluetooth tells me the status of the battery, but won't adjust the volume up or down
I just got mine and had the same problem. After messing with it for a bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Feb 23, 2013 | Jabra Extreme2 Bluetooth Headset
I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
May 06, 2011 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
Bluetooth stopped connecting - solid light
I followed one of the solutions that I found on your website! I deleted and added the connection on my phone again and used 0000 as the pin number.
Worked great!
Apr 09, 2009 | British Telecom Jabra BT2010 Wireless...
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Jan 03, 2008 | Radio Communications
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT125 Headset Logo
15 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
