Question about Canon PIXMA MG5320 All-in-One Printer
Persisting error code B200
Persistng error code b200
  • 310 Answers
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Posted on Mar 03, 2008
SOURCE: CANON PIXMA iP3300
1. turn off printer
2. Hold down resume, dont realase and press power button
3. realase resume button, now press twice resume button but dont realase power button
4. realase all.
5.now press twice again resume button and plug off power cable
6. turn on printer with plugin power cable
7. your printer will reset.
iff not working, you must chek pointing contact in head printer, use some claener with cottonbuds to clear the contact.
may you sukses!!!
Posted on Dec 19, 2008
cns assoc
  • 677 Answers
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
Posted on Nov 07, 2009
Democritus
  • 120 Answers
SOURCE: What is service error B200?
According to Canon's documentation, this is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board; a physical hardware malfunction.
This is Canon's official stance on the error:
Turn off the machine, and unplug the power cord of the machine from the power supply. If the problem is not resolved, contact your Canon service representative.
After looking a bit more, I discovered that the B200 error is a Voltage High Error on the iP4500 chip. Try calling Canon tech support at 1-800-828-4040. If your printer is still under warranty, they will probably send you a new printhead or a new printer.
Posted on May 26, 2010
  • 37 Answers
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Canon MP276 show a error number B200. how i solve it?
FIXED: Canon Printer Error B200 With 5 Different Solutions ...
? 3:33
www.youtube.com/watch?v=LZELHKjVZAY Mar 18, 2014 - Uploaded by ITJungles Five different solutions you can try to fix the Canon printer error B200. Is your printer playing up and not doing ..
Jul 22, 2015 | Canon Office Equipment & Supplies
Canon mg5250 -error code B200
B200 usually means that the printhead has failed. It's a generic "overtemperature detected" error that indicates that the thermal sensors inside the printhead have detected heating to the point where the printhead has probably failed. In a well-intentioned attempt to prevent further damage, the printer has shut itself off; however, by the time this occurs, the printhead is usually destroyed. The following video shows a likely next step: http://www.youtube.com/watch?v=I9uBEOMCd44
Jun 05, 2013 | Microsoft Windows 7 Ultimate for PC
B200
Hi there!
If you're getting the error code B200 when you try to print on your Canon PIXMA MX850, there is nothing you can do except to have it repaired. This error code indicates a Voltage High Error of the Canon printer. If the printer is still under warranty, please contact Canon for further assistance.
Jun 26, 2011 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Canon Printer Pixma MP540 with error code B200 - what can I do? Thank you for your support. Arthur
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Feb 12, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Error code B200 on a MX850, what do i do?
Best solution for B200 error code:
http://www.youtube.com/watch?v=AyHaxjFg8aI
May 12, 2008 | Office Equipment & Supplies
Canon PIXMA MG5320 All-in-One Printer Logo
55 people viewed this question
old marine
old marine
