Question about Gateway 500 X PC Desktop
Gateway 500 x remove the front panel - Gateway 500 X PC Desktop
How do I get to the belt moter on a sears Kenmore 500 cloths dryer the belt is off but not broken
The usual method of accessing the belt is to remove the entire fron panel (including door). It is usually easy to remove the panel by removing a couple of screws at the top and pulling up and out on the panel. The belt can be reached from the front. All dryer belts have a spring loaded tensioner on the belt. Check the tensioner as belts hardly ever come off unless the tensioner spring breaks.
Oct 20, 2014 | Kenmore Dryers
HOW TO REMOVE THE FRONT PANEL
What is the model number of your PC?
Jan 05, 2014 | Gateway Computers & Internet
How to remove front panel off my older gateway essential
if it has a molded plastic front panel, most have one version or another of plastic tabs or snaps holding it to a frame.. you just have to try to carefully pry the front away from the case with a thin tool... other types of front panels can be riveted in place and basically not removable..you can usually see what type of construction the case is by removing the side panel and looking at the front panel from the inside...
Jan 04, 2014 | Gateway Computers & Internet
HOW TO REMOVE FRONT PANEL OFF THE GATEWAY ESSENTIAL
  • Remove the side panel first to make the front bezel easier to access. To remove the side panel, remove the thumbscrew from the side panel cover. If the thumbscrew is very tight you may need to use a screwdriver to loosen it.
  • Lift up the release lever to loosen the side cover. Carefully swing the panel away from the computer and lift the panel away. Set the panel aside.
    Move the computer slightly forward on the desk so that the top and the bottom of the case are both accessible. Pull the bezel out and lift it free of the case. Set the front bezel aside until it is time to reassemble the unit.Read more: http://www.ehow.com/how_5775555_remove-panel-gateway-e_series-computer.html#ixzz2pxkABtPy
    Replacing a power switch on a gateway tower
    The plastic front of your computer is the Front Panel
    http://support.gateway.com/s/PC/R/1009566/1009566nv.shtml
    Slip this off to access the Power On Button assembly, which has the Power On switch inside it,
    Outside view,
    http://support.gateway.com/s/CASES/GERSHWIN/8016200R/8016200Rmv.shtml
    Rear View,
    http://support.gateway.com/s/CASES/GERSHWIN/8016199R/8016199Rrv.shtml
    -> FOLLOW Anti-Static Procedures -> BEFORE reaching inside, your unplugged from power, computer.
    If you do not know, post back in a Comment
    Now look at the Rear view of the Front Panel again.
    The LEFT Side Panel removes.
    Looking at the Rear view of the Front Panel; note that the LEFT side of the Front Panel, is towards the Bottom.
    See the three TABS sticking up along this edge?
    One at the Bottom, one in the Middle, and one at the Top.
    Flat plastic TABS formed out of the Front Panel itself.
    Another point of view.......
    The metal framework you see that the CD/DVD drive/s are in, is the Optical Drive Bay.
    Look at the Optical Drive Bay, and towards the Top/FRONT.
    See that flat TAB sticking in from the Front Panel?
    Now come down to the Middle of the Front Panel.
    See how out at the bottom of the Optical Drive Bay, there is a TAB sticking in from the Front Panel?
    See the TAB at the Bottom?
    They hook on the metal framework of the computer case.
    They go through SLOTS in the metal framework.
    The Tabs are pressed to the Inside of the computer case, OR to the outside of the computer case.
    This action brings a hooked end on the end of the TAB, to the Middle of the slotted hole it\'s in, and then the Tab is free.
    Suggest start with the Bottom TAB, press on it when hooked end is free of slot; then do the same for the Middle TAB.
    Now perform this on the Top TAB.
    The TABS are pressed to the inside, or to the outside, and pressure is put against them towards the Front Panel.
    Push on the Tabs, to push the Front Panel away from the computer case.
    Once all three TABS are free, the Front Panel will swing out, and remove.
    Power On switch is mounted to this metal case,
    http://support.gateway.com/s/CASES/GERSHWIN/8016038R/8016038Rmv.shtml
    Me?
    I would open that case, and take the Power On switch itself, out.
    Then see if I could find a replacement, or one that I could live with,
    http://www.ebay.com/sch/i.html?_nkw=atx+power+switch
    Direct link to Hardware Reference Guide,
    http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
    Let\'s see if it works.
    If not here is the Gateway Support page for it.
    http://support.gateway.com/s/PC/R/1009566/1009566ul.shtml
    8512041 - Gateway Hardware Reference Guide (5-Bay uATX Case)
    Go to Pages 37, and 38. (Top of Adobe Reader in page number box)
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Apr 19, 2013 | Gateway GM5472 PC Desktop
    Removing front panel on DX4860 UR11P
    First remove the side panel so that you can see the catches that hold the front panel to the metal frame. There might be a screw or two on the back of the computer that holds the side panel that you will have to remove. Most newer model computers will only allow the removal of one side panel. Once you remove the side panel look inside towards the front near where the side panel was and you will see plastic catches that hold the front panel to the metal frame. Push the Plastic catches so that they will release the front panel.
    May 30, 2012 | Gateway Computers & Internet
    How Do I remove the cover from a Gateway 500 series???
    Like this Gateway SE?
    http://support.gateway.com/s/PC/2800071/280007101.shtml
    On the back of the computer remove the screw from the top middle.
    Now remove the screw on each outside edge, down towards the bottom.
    Hold the outside shell, or computer cover. Push the inside forward.
    The computer cover comes off like a shell, or bonnet.
    http://support.gateway.com/s/PC/2800050/280005003.shtml
    If this is a reference to a Gateway 500X series, remove the thumb screw/s from the back of the computer, on the right side. (Right side as you are facing the back of the computer) Then slide this Side Panel towards the back of the computer.
    Regards,
    joecoolvette
    Dec 19, 2010 | Gateway 500 X PC Desktop
    I cannot get the side panel off my gateway 500xl
    The Gateway 500 xl has a release button (quite wide) on the inside at the top of the panel. Simply press this release button and pull the top of the panel away from the computer. It then lifts off.
    Apr 10, 2009 | Gateway 500XL PC Desktop
    Gateway 500 X PC Desktop Logo
    16 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
