Question about Eljer 141-0220-00 Toilet Tank White
Where do you find the model number on an Eljer toilet tank?
  • 10865 Answers
SOURCE: toilet tank replacement
I believe you will find it cheaper to replace the whole toilet. good luck
Posted on Jan 24, 2009
gypsycat00
  • 224 Answers
SOURCE: I havve two Eljer non-wateraver toilet (Patriot?)
I've never had a problem with Eljer toilets. Try adjusting the fill valve so that it allows more water to enter the tank (if you're over the flush valve, install a coupler made from PVC around the neck of the flush valve- inside diameter of the coupler needs to be the same as the outside diameter of the flush valve filler neck).
Posted on Jul 10, 2009
radar001
  • 1051 Answers
SOURCE: My Eljer toilet does not always flush completely.
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Posted on Feb 26, 2010
  • 33 Answers
SOURCE: Where do I find the model # / type on an Eljer
maybe you can find it at www.eljer.com
or their customer service
800-442-1902
Monday through Friday
8:00 A.M. to 6:00 P.M. EST
Posted on Aug 03, 2010
  • 1739 Answers
SOURCE: I am looking for a
I checked the Eljer website; several different toilets came up searching with the number you provided but
no information on a Preserver model.
I think your best bet would be to contact your nearest dealer for the Eljer products. You can use the location finder on the Eljer website:
http://www.eljer.com/dealers.aspx
It is possible a dealer may have old stock oand should know if there is a substiute available.
Posted on Mar 02, 2011
If there is a model number you will have to remove the top tank and look on the bottom of it.
good luck
Apr 18, 2014 | Eljer 141-0220-00 Toilet Tank White
Where do I find a part number on an Eljer toilet tank?
You can purchass a whole new fixture for the same cost as just the tank I believe...
any eljer tank will fit your toilet bowl... they are pretty universal.
Does the current tank have a crack or something?you can replace the seals easilly enough if the tank is just leaking at the seal ... and the flush mechanism is also easy to replace , should that be the reson to swap out tanks too.
Mar 24, 2013 | Eljer 141-0220-00 Toilet Tank White
TRYING TO FIND PART ELJ-141-- 0220 THIS GOES BETWEEN TANK & TOILET
i went directly to eljer and could not find the part corresponding to the numbers you provided but if you are talking about the rubbery gasket, that goes between tank and bowl, it can be found at any local plumbing supply...most likely...and if it is the gasket you need then it does have to be exactly the right one or the tank will leak. if you're having trouble finding Eljer parts i would just buy a"fluidmaster" tank rebuild kit from home depot,lowes,ace,true value, etc (fluidmaster is everywhere) hope this helps but if you need anything else just ask:)
Jul 29, 2011 | Eljer 141-0220-00 Toilet Tank White
I am looking for a replacement toilet tank lid for a Eljer Preserver II toilet. Manufactured in 2003.
Mar 02, 2011 | Eljer Toilet Tank Lid Preserver II ...
Where do I find the model # / type on an Eljer wall mount toilet with seperate exposed tank?
800-442-1902
Jun 05, 2010 | Eljer & Elongated Toilet Bowl
Eljer 141-0220-00 Toilet Tank White Logo
65 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
