Question about Krups ZY403851 Juicer, Definitive Series Stainless Steel Extractor
Krups juicer; how to remove the filter basket for cleaning?
Krups ZY403851 Juicer with the stainless steel basket. How to remove the basket for cleaning?
How do you take it apart to clean it ?
It's really easy, you take down the metal bar and the top comes off, then you should see the orange mesh basket which is removed using your little tool - it's like a key which you turn to remove the basket - rinse under the tap - piece of cake.
Mar 15, 2010 | Jack Lalanne Power Juicer (Stainless...
For an Oster Juicer Model 3165, how do I remove the stainless steel basket? Thanks.
Move from side to side and jiggle the whole assembly .. including the juice collector and juicing basket. With patience and even a break between attempts it will finally dislodge itself and lift up and off.
Just juiced carrots and a couple apples .. mmmm good ;-) best of luck
Aug 23, 2009 | Oster 3186 Citrus Juicer
Open to clean juicer maching
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Jack Lalanne's Power Juicer Manuals of all models which include troubleshooting guide, user instructions, cleaning and opening machine.
Jul 13, 2009 | Jack Lalanne Power Juicer (Stainless...
STRIPPING DOWN THE JUICER FOR CLEANING
Yes.  There should be an orange handle-looking accessory with to small metal rods sticking out that is made to clik into the wire mesh screen and unlock it be twisting the screen mechanism slightly so you can unscrew it out.
See the enclose photos of the tool.
Hope this helps...
-enov8
Mar 03, 2009 | Jack Lalanne Power Juicer (Stainless...
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Cleaning instructions
Try this. It works for the Stainless Steel juicer as well:
http://www.dooyoo.co.uk/juicer/jack-la-lannes-power-juicer/1055142/
Jul 31, 2008 | Jack Lalanne Power Juicer 250 Watts
Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Smitty
Jun 06, 2008 | Jack Lalanne Power Juicer (Stainless...
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Krups ZY403851 Juicer, Definitive Series Stainless Steel Extractor Logo
535 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
