Question about Olympus VN5200PC Voice Recorder
Memory error showing memory error 512 memory
I have a HP a1514n media system with 2 - 512 sticks of ram. I replaced one of the 512's with a 1GB stick and my system only shows 1024 ram available. I checked the settings in startup and it shows...
First of all, make sure you have the right memory - 240 pin, DDR2 SDRAM, PC2-4200 MB/sec.
Your machine should support the memory as it has two banks of 1. Sometimes it is simply a sequence problem. In older machines with mixed memory, I always put the largest and fastest in the first slot. You might try just reversing the memory.
Jul 19, 2011 | HP Pavilion a1514n (EX269AAR) PC Desktop
Lost driver & installer
hello
due to the fact that this memory card is no longer available, Kingston does not have drivers fo this card . As a matter of fact SD cards normally do come with drivers , as they are conformed in a way that operating systems recognise them once you plug them into the SD slot
i hope this inofrmation helps you make a decsion
some background on this particular SD memory card you have
SDCZ2-512-A10-KT (Discontinued) Description: 512MB USB 2.0 DataTraveler I write up to 3MBps Discontinued Additional Info: DataTraveler I USB 2.0 Flash Drive Write up to 1.5MBps Read up to 6MBps Mfgr's System P/N's: SDCZ2-512-A10 (Kingston) Form Factor: USB Flash Memory Warranty: 5 Yrs†
here are some solutions .
When the problem occurs is a clue as to the cause.
For example, your response to a memory error message depends on whether:
  1. You have just bought a new computer.
  2. You have just installed new memory.
  3. You have just installed new software or a new operating system.
  4. You have just installed or removed hardware.
  5. Your computer has been running fine and you've made no other recent changes.
UNEXPECTED PROBLEMS
If your system has been running fine, but suddenly starts to produce memory errors, and crash or lock up frequently, the chance of a hardware failure is more likely, since configuration and installation problems show up as soon as the computer turns on. Sometimes you can get memory problems if your computer is overheating, if you are having a problem with your power supply, or if corrosion has developed between the memory module and the socket, weakening the connection.
HANDLING SPECIFIC PROBLEMS
Here is a list of the most common ways the computer informs you of a memory problem.
  1. The computer won't boot, merely beeps.
  2. Computer boots but doesn't recognize all the installed memory.
  3. The computer boots but the screen is blank.
  4. The computer reports a memory error.
    1. Memory mismatch error
    2. Memory parity interrupt at xxxxx
    3. Memory address error at xxxxx
    4. Memory failure at xxxxx, read xxxxx, expecting xxxxx
    5. Memory verify error at xxxxx
  5. The computer has other problems caused by memory.
    1. The computer intermittently reports errors, crashes frequently, or spontaneously reboots.
    2. Registry Errors
    3. General-protection faults, page faults, and exception errors
Nov 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
Sir how much graphic memory can spport my p5nmx-mx mthr board with 3gb ram inbuilt graghic memory means how much graphic memory it will show when i will use 3 gb memory {available graphic memory}
the max you will see if you are running vista is 1244. shared memory is calculated as followed.
(total memory-512)/2= dedicated shared video memory. (3000mb-512=2488/2=1244mb dedicated shared memory.
Nov 04, 2010 | ASUS Computers & Internet
Memory not correct
hello..the 1 (one) off is a compatible the PC2100 to PC2700 u need same FSB..do not use not same FSB...Thanks and Good Luck..^_^
May 19, 2009 | Computers & Internet
Whem i try to copy data from PC to card, it shows I/O error.
u need card reader for that.
connect your memroy card to your computer and put your memory card in cardreader then u can easily acces it.
Mar 23, 2009 | Kingston flash memory card - 256 MB -...
After upgrading RAM 1G to 1.5G
The BIOS will recognize the new ram when the pc is turned on. If the amount is being reported correctly and there are no beeps you are good to go.
Feb 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Toshiba satellite a100,wa-1 memory upgrade
Take out all the memory cards and wipe the gold part of the memory modules.
Then insert the two 512 modules & check the memory.
If it shows the correct readings, then the two modules are detected.
Then insert the 1 gb & other one 512 module.
Then use the other one gb with the same 512 & check if it shows the correct readings.
Then the two 2 gb modules are fine.
Now insert the two 1 gb modules & check now.
There are ECC type & non-ECC type memory modules are available, chck which one your computer supports & which type you have.
If it shows the correct readings, then the two modules are detected and fine.
Then you can also swap the slot and check if any memory module is not detectd correctly.
Some have four slots & i dont know how many slots your laptop have.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Toshiba Satellite A100-S8111TD Notebook
Canon MV750i memory card
http://www.memory-up.com/Memory/CanonMV967.html shows that the max is 512
Apr 14, 2008 | Canon MV750i Mini DV Digital Camcorder
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
Olympus VN5200PC Voice Recorder Logo
62 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
