Question about MSI GT70 ONE-446US Black 17.3" Notebook 2.4 GHz Intel Core i7-3630QM, 16 GB DDR3, 750 GB HDD 128 GBx2 SSD, BD-ROM/DVDAAAARW DL, NVIDIA GeForce GTX 680M, Windows 8, LED Backlight
Dark screen, computer is on but the screen is dark
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computers & Internet
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    IBM T61 remains with dark blank screen but is on.
    Connect it to another monitor,and see if it comes on. Your screen may be damaged.
    Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
    A90f dark dark screen
    Use brighten controls on monitor to lighten
    Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
    Dark LCD screen. Very faint image.
    Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
    good Luck
    Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
    Dark screen
    reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
    Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
    Dark screen
    you may need either a new lcd, or a motherboard, or both..lcd is usually the first issue to resolve..does it work , by chance with an external monitor?
    check your computer warranty here 4 FREE
    Feb 29, 2008 | Sony VAIO PCG-K23 Notebook
    Dark screen
    Your backlight is probably burned out. It is repairable, but I recommend having a computer repair shop take care of it.
    Jan 28, 2008 | IBM ThinkPad G40 Notebook
    Dark screen
    contrast or brightness problem.
    Dec 08, 2007 | Toshiba Satellite A20 Satellite A25 Series...
    MSI GT70 ONE-446US Black 17.3" Notebook 2.4 GHz Intel Core i7-3630QM, 16 GB DDR3, 750 GB HDD 128 GBx2 SSD, BD-ROM/DVDAAAARW DL, NVIDIA GeForce GTX 680M, Windows 8, LED Backlight Logo
    12 people viewed this question
    Top MSI Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a MSI Office Equipment and Supply Expert? Answer questions, earn points and help others
