Open maks monitor soket data cable of 5 pins to order the coloured wires
Hello, i Need to know the order of wirs colours for the Sub data cable which socket on the Screen board of open maks 0 50p Screen 14" and must be Connection for the colours wires which White,brown,green,yellow,red or orange for Pins UIN;HIN;D-SDA;D-SCL;GND in the right order and thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
This site has all the answers...:)
http://www.digilentinc.com/Data/Documents/Other/Connecting%20I2C%20Interfaces.pdf
Posted on Jun 22, 2014
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 16, 2008
SuperTech-11
  • 1591 Answers
SOURCE: TW10794V-0
If you tell us what the monitor is doing, the solution may not require knowing what voltage is at what pin - especially since some of the voltages may be oscillating!
Posted on Dec 12, 2012
pravinbhavsa
  • 348 Answers
SOURCE: Samtron 78DF signal cable conductors
1) red
2) green
3) blue
4)gnd
5)gnd
6) red return
7)green return
8)blue return
9)+5v from vga card
10)stand by
11) synchronus gnd
12) Sda
13) Hsync
14)V sync
15) Scl(serial clock)
Posted on Sep 28, 2013
Testimonial: "Thanks, but you are 6 1/2 years late with the answer! It was solved in May of 2007."
All my wires in my monitor r unhooked where they go can you tell me.
If your wires are unhooked, Usually new monitors wires are colour coded , for example, blue to blue, yellow to yellow etc.
If your wires are not colour coded, There is only one way the wires can go, They won't fit just anywhere. If they fit into one connector, then that will be where it needs to go.
Hope this helps
Mar 13, 2011 | E-Machines T2642 PC Desktop
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Colour problem
This is a problem that is associated with some electronic components inside your monitor. Also it can happen if some of the pins on monitor's data cable (that connects to CPU) are bad or the cable itself is bad. Anyway you have to go to an monitor repairing shop.
Jan 01, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Problem with the vga cable
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Mar 31, 2008 | SAMTRON 55V 15" CRT Monitor
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
