I have a whirlpool cabrio he washer When the cycle is done my clothes still have a little bit of water so I have to run the drain and spin cycle any help
  • 1,087 Answers
Your pump is most likely in need of change. They are $90 on Sears website do it yourself not that hard. Its a plastic housing with a cpl rubber connections under the washer. Set the washer on its face the pump located on the left bottom.
Posted on Jun 09, 2014
  • 1294 Answers
SOURCE: clothes are soaking wet after cycle is done
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Feb 02, 2008
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 1550 Answers
SOURCE: my washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Posted on Jan 31, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
I have a Whirlpool LHA 5700 old school washer. It works great. It wash clothes with no problems. It just stop spinning the water out tub and clothes. The water drains as far as it can but that's it. W
Don't know the model but with the old basics with electric motor drive as a 1st step always check for broken wires to the motor as they flop around a fair bit and eventually break them or corrode them from water and washing detergents.
Apr 19, 2014 | Whirlpool Washing Machines
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5600xw0 will not spin
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
May 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Clothes wet when cycle is done
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt , a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
