Question about Epiphone Music
Can not find where blue wire goes
Wiring
    New Friend:
  • 25 Answers
You must at least name the piece of equipment and where the wire is located...
Posted on Apr 23, 2014
Wiring for the arm head where the needle goes. Wires were unplugged by accident now not sure how to plug them back in. Rockola sybaris 474.thanks
Thee is a standard wiring connection for stylus cartridges. Looking at the rear of the cartridge, there are four connections. With the stylus point down, starting at the top left and moving clockwise:-
White wire - Left channel out (10 o'clock)
Red wire - Right channel out (2 o'clock)
Green wire - Right channel ground (4 o'clock)
Blue wire- Left channel ground (8 o'clock)
Alternately the connection arrangement could be in a vertical line with alternate pins staggered. In this arrangement looking from top to bottom it will be :-
White wire - Left channel out ( Top left)
Red wire - Right channel out (Second right)
Blue wire- Left channel ground (Third left)
Green wire - Right channel ground (Fourth right)
I hope this helps
Nov 24, 2017 | Music
I have a pignose amp with a blue wire that I don't know where it goes.
If you can upload photos of the wire and the board of the pignose maybe I can help.
Thanks
Nov 15, 2014 | Music
Sp 3g crossover wiring color code
Horn is red +, black -, mid is white +, blue-, lows are yellow+, blue-. If you look at the crossover board, you'll see the treminals are labeled what goes to where.
Apr 21, 2014 | Peavey Music
Can no find where blue wire from the back goes to
the color of wire doesnt necessarily tell me anything. what you can do for me is 1, trace it and tell me what it is coming off of, 2. is there any other wires with kit and where they lead to. 3. and where it is severed . with that information i may be able to help you. pictures help also
Apr 19, 2014 | Epiphone Music
Which wire yellow or blue goes on red post
Peavey color indicates that Blue is Negative And Yellow Is Positive, so Yellow goes to + Speaker Terminal.
Feb 03, 2012 | Peavey SP2 PA Passive Speaker
I have a Marshall channel/dfx footswitch. The jack plug has been chopped off leaving me with a red, blue and yellow wire. Can you tell me where each one is soldered to on a replacement stereo jack plug?...
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Apr 11, 2011 | Marshall Amplification Marshall Footswitch...
Wiring diagram pignose 7-100 guitar amp which wire goes where?
There are a couple thumbnail sketches of the diagram at:
http://music-electronics-forum.com/t8790/
They are down about 3 an 6 of the blogs.
Nov 29, 2010 | Marshall Amplification Marshall Mini Stack...
Jack on guitar looks like a wire broke off. One blue wire still connected. No loose wires floating around! Should there be 2 wires connected to the jack itself? Which two?
There should be two wires connected. One goes to the jack tip while the other goes to ground. One lug on the jack is connected to the part touching the sleeve on your cable while the other will contact you cable's tip. There is another wire in there somewhere.
Jul 01, 2009 | Epiphone Les Paul Studio Electric Guitar
Mackie 1604 Power Connector orientation
Here's a shot of the connector, mated to the motherboard.
Mar 27, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
20 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Vito Vacirca Jr.
Are you an Epiphone Music Expert? Answer questions, earn points and help others
