Question about GS11 Double Eagle Adjustable QAE Airsoft Gun Red Dot Scope
GS11 Double Eagle Adjustable QAE Airsoft Gun Red Dot Scope wont come on
I put a fresh battery in my gs-11 and it will not turn on
I just took my M82 airsoft gun out of tthe box and when I turned on the scope the red cross didn't come on. I can't figure out why.
There will be a protector over the battery, to keep it from going dead during in store shelf storage. Hope this helps Fix Ya up.
Jun 23, 2011 | AEG Optics
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
NEED INFO ABOUT ADJUSTING WINDAGE & ELEVATION ON MY MILLETT SP2 RED DOT. I LOST OWNERS MANUAL &NEED TO KNOW WHAT EACH CLICK IS EQUAL TO AT 100 YDS
the best way to sight in your red dot is clamp your gun in a gun vice or work mate? so it cant jump about!!!!!!! look through the barrel at a post say 100yds away then tweek the red dot or croos onto this post,,then test fire the gun and tweek the scope till its shooting were it points,,easy,,,
dont let the gun move at all,,,,you need to remove all the wobbely bits,,your the bigest wobbely bit?
an im not being nasty,,,you cant tweek a scope hand held?
Nov 27, 2010 | Millett SP2 Compact Red Dot Sight 5 Min...
I have a 16-A WELL air soft gun that broke, i need solutions.
Its a well airsoft gun which=**** get a better airsoft gun and you wont have to deal with that ****
Mar 13, 2010 | Laser Automatic Airsoft Rifle Gun with +...
I want to fix my mossberg airsoft shotgun
how do i fix the inside of the 590 tactical airsoft gun
Jan 20, 2010 | Laser Automatic Airsoft Rifle Gun with +...
Airsoft battery busted
New battery is all i suggest , you really screwed it up it probally wont work but if it does it will eventually blow up on you as it is not discharging properly, but there cheap if there locally available. So just get a new one and dont play with the wires next time and get a proper airsoft gun.
Jan 17, 2010 | Laser Fully Automatic Electric M4a1...
My laser for my m82 airsoft gun is broken and i think its the wires that meet to make the laser turn on . Can anyone help me
follow the wires to and from the laser. There should only be two wires that make it work. A positive and a negative wire that hook up where the battery connect. if the wire is not connected you have to make the connection again. To make it stay connected you may have to soder the wire back together. Also, double check that the batteries have not ran out of power.
Jan 08, 2010 | Laser Fully Automatic Electric M4a1...
My r34 crossman stinger is all apart is there any picture of the inside
Its a crossman airsoft gun= piece of **** get a quality brand airsoft gun instead. If you managed to take it apart i think you can put it back together
Sep 24, 2009 | Laser Automatic Airsoft Rifle Gun with +...
I put in a new battery thinking that might be the problem, after installing new one, it did not work, while fiddling with it the dot came on for a second then off and nothing I did could get it back on,...
take out the battery or batteries.
turn the scope on to full power.
place the battery or batteries in the scope.
just start the battery compartment cover onto the threads.
watch through scope as you slowly tighten cover.
If the dot lights up stop turning cover or experiment with continuing to thread on cover.
Apr 13, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
How to load airsoft gun
Airsoft is a game developing in popularity as far as wide and possible, offering a enormous scope of imitation weapons for a mixed bag of diversion situations. Stacking an Airsoft weapon will fluctuate by the kind of firearm, and in addition by maker. Most Airsoft firearms offer a removable magazine into which the ammunition is loaded. It is not a troublesome methodology, and just about anybody can stack one of these weapons.
Feb 21, 2009 | Sport & Outdoor - Others
GS11 Double Eagle Adjustable QAE Airsoft Gun Red Dot Scope Logo
93 people viewed this question
Top GS11 Sport & Outdoor - Others Experts
Are you a GS11 Sport and Outdoor - Other Expert? Answer questions, earn points and help others
