Question about Acer Aspire One Netbook 8.9" Notebook
Will not start says system 32 corrupt or missing was working before and keeps adding gigabits
    Top Expert:
  • Acer Master
  • 5,143 Answers
Run a virus scan if and when you get up and running,,try starting up in safe mode.
Posted on Apr 05, 2015
3 Suggested Answers
  • 189 Answers
SOURCE: file: /windows/system 32/gqcpmf.sys
You need to reload your operating system or a part of it. Most of the time this is caused by the OS disc that the system was loaded from could have been dirty or scratched up. Try an reload and don't rush the process this will also give you mixed results.
Posted on Jan 23, 2010
I have an HP 6200 pro desktop that I am having trouble finding the correct drivers for the 82579LM Gigabit network Ethernet connection. Can you Help?
what you need to know is what operating system does the hp 6200 pro desktop run on ?
from the specs on the hp 6200 pro desktop
it might be
Microsoft Windows 7 Professional 32-bit
Then download the correct driver for the operating system you are using
https://downloadcenter.intel.com/product/47549/Intel-82579-Gigabit-Ethernet-Controller
and then either run the download or point the update driver to the folder the driver is downloaded into .
Depends on the type of driver you download as to whether it installs itself or has to be added via updating the driver and pointing to its location after it copies its extracted files if it is compressed.
Apr 29, 2017 | HP Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Reinstall windows root system 32 hal.dll
Do a start up repair.
Insert your Windows Operating System disc in the DVD. Reboot your computer and press any key when you see the phrase "Press Any Key to Boot in CD".
Select the start up repair and it should work after the loading process.
I hope this helps.
Carlo
Jan 23, 2013 | Dell Inspiron Computers & Internet
Missing files to run skype
Just re-install the skype again but if the problem still occurs then i would suggest to use a system utility tool like Reginout to fix this problem. Sometimes this problem occurs due to corrupt registry files or due to missing dll files.
May 03, 2012 | Acer Computers & Internet
Cannot start cp message system32 is missing is there an easy fix
use your cd windows to make system recovery or you can connect your hard disk to other same operating system pc then copy your windos fail and do a scandisk on your hdd
Mar 09, 2012 | Gateway MX Computers & Internet
System 32 corrupt or files missing ,wont go to repair
To repair missing or corrupted system file/s, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4482455-repair_windows_xp
Nov 11, 2010 | IBM ThinkPad T22 2647 Notebook
I am getting this message when booting up my Gateway 250rog: "Windows could not start because the following file is missing or corrupt: &lt;Windows root&gt;\system32\hal.dll. please...
It appears the .Hal file is missing or corrupted. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks & regards,
Anil.B.R
Nov 04, 2010 | Gateway 450ROG Notebook
I can not get my system boot up it says Windows 32 /system file missing.......... what to do
Your operating system seems to be Corrupt. you need put windows xp Cd and repair the windows
Apr 21, 2009 | Computers & Internet
Control panel icons and properties tab are not working
The first step is to scan for spyware. These nasties can alter system files. Download MS Antispyware and Ad Aware and scan or spyware.
Also run a system file checker command to update any missing files Go to Start>Run>type "sfc /scannow" without quotes.
Note: it is advised to keep the original windows CD handy while prforming SFC \scannow as it tries to update the missing/ corrupt files.
Regards,
Arpit
Apr 19, 2009 | Computers & Internet
Windows 32 file is missing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0mm 5.4pt 0mm 5.4pt; mso-para-margin:0mm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows 32 file is a system file this one along with others if faulty or corrupted will stop windows working
The easiest way in the long term is to.
Boot from Windows CD and after all files are loaded. Windows will ask you what you want to do. Install, Repair etc. Choose repair and follow instruction from there Windows will remove some files and reinstall in repair mode. You will not lose any files, during this process.
The reason I choose this method is because you can spend some hours trying to fix not starting problems and not succeed while a reboot in repair mode takes ¾ of an hour plus time to load drivers
Oct 17, 2008 | Intel D845GVSR Motherboard
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
