Question about Westinghouse Computers & Internet
Check source and connection - Westinghouse Computers & Internet
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
No image just light
double check your connections and which source you are connected to.
Does the original source funtion properly?
What is the original source?
If laptop, check display options for the video output.
Feb 12, 2013 | NEC LT380 LCD Projector
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
The projector finds my VGA port and projects for a second or two, and then loses it, displaying the word "lost"
First check it with new best quality VGA cable. If the problem is still there, change the source connected to VGA port (i.e. Laptop or PC). Sometimes such things occur in Auto Source. Remove Auto Source from the menu for automatic selection of source. Keep the VGA port as first source to display. You will have to check it in the menu. In spite of Auto Source you can always select your desired source with source button also. If problem is still not corrected tell us the Make & model of the projector so that it can be better diagnosed.
Aug 06, 2011 | Office Equipment & Supplies
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
After switching on the projector displays message 'searching for source' then 'no source found'. Computer is connected to Optima EP7155 using vga cable.
1 check VGA cable for damage (try other cable)
2 check connections
3 make sure you have resolution on PC is faling in projectors resolution range
4 if it is laptop, make sure you have it in external monitor mode (usually Fn + F8 keys)
Mar 01, 2011 | Optoma EP7155 Projector
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
Have HP Photosmart Premium C309. Cannot get phone signal through port "2-ext" ???
Be sure that the source/wall to the printer line 1 is working then connect a phone on the line 2 ext and check if there is a dial tone, if not, the printer needs replacement.
note: you can connect the phone directly to the source/wall to check if the source/wall really has dial tone.
Aug 29, 2010 | Office Equipment & Supplies
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
I keep getting disconnected from the internet
Check your internet cable for loose connections, If you are using Windows XP, try the following methods:
1. Go to the Control Panel; right click on the Network Connections.
2. On the dialogue box, click Status; the Local Area Connection Status will appear, check if its is connected or not. If it is connected. Unplug the power source to your internet cable/connector.
3. Restart, your computer;then re-plug your internet power source.
4.Wait for at least 30 minutes then check your browser.
5. If there is no internet signal, you should call your internet provider's technical service.
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
