Question about Samsung HL-P6163W 61" TV
Samsung turns off after about a minute and has three blinking lights
Ive cleaned the fans and pulled the bulb. the picture looks normal but the tv randomly turns off.
SOURCE: Samsung dlp hdtv turns itself off
We had this exact problem with our Samsung DLP about a year ago (it was 2 years old at the time). We purchased a small desk fan for $6 and placed in behind the TV. We started running the fan when watching and it fixed the problem of the TV clicking off. It was inteded to be a short-term fix, but since it's worked so well we still haven't gotten the TV fixed.
Posted on Jan 15, 2008
ladywinn
  • 5138 Answers
SOURCE: Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Posted on Feb 20, 2008
IB4G2008
  • 3587 Answers
SOURCE: Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Posted on Mar 24, 2008
jingjao
  • 252 Answers
SOURCE: SAMSUNG DLP HL-S5086W
check the horizontal transistor if, good.re solder your tv.
Posted on Oct 02, 2008
SOURCE: Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Posted on Aug 31, 2009
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
My samsung dlp hl-s5686w turns for a minute video disappears audio continues and three lights flash the standby/temp,timer,lamp. all at the same time.
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
Apr 30, 2010 | Samsung HL-S5686W 56" HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Sep 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P6163W 61" TV Logo
Henry  Thomas
Henry Thomas
