Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
I have e602-0003 error on ir3300 copier after a power failure
It was after a power disruption during photo copying
    Sniper:
  • 105 Answers
Check The Disk
And Reset All Data.
Or replace A HDD
Posted on Mar 28, 2010
    Sniper:
  • 89 Answers
Agree with ramasaai.
Turn copier off (using main power switch on right hand side of copier), then turn on again while pressing 1 and 9. Hopefully rectangles start dropping on the screen and eventually that finishes and it says download mode. Connect computer to copier using SST and format hdd and reinstall system software. HDD is on the way out and will almost certainly fail soon even if this works.
If you're not a tech call a tech and get it done right.
Posted on Jul 24, 2009
    Sniper:
  • 54 Answers
  • its a hard disk soft ware problem, try to format the hard disk and reinstall the software.
  • replace the hard disk with new one.
Posted on Jun 29, 2009
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
Aug 02, 2014 | Canon IR 3300 Digital Copier
ERRCODE 00064-0000
Did you try to think about replacing DC Controller (FG3-1998-020) i
Jun 30, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Error code 000000-0000 in connon ir3300
The error code E000000-000 means that you have a problem with the fuser unit. Did you have a power outage recently???? That may have been the cause of the code. Or you may need a new fuser unit... Did you try to rest the error code in service mode?????
Mar 29, 2011 | Canon Office Equipment & Supplies
Can't recall my management ID and password for my IR3300. Any advice on retrieval without disrupting the present configuration of the system?
Can clear this in service mode.
Copier > Function > Clear
Use right arrow key to go to screen two, select PWD-CLR (password clear), hit OK, then press the reset button twice to return to main LCD screen.
Jan 30, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Heater Unit & Hard Disk problem ir3300
1) what kind of hdd failure? Did copier report error code like E602-0003, or? When the hdd error occured did the service exchange HDD with new one and upgrade the system. Other thing, but not mostly likeble, check the current in el. insert.
2) Wich kind of problems? Did the copier reported E000, E001, E002, E003,..., is there was smudged copies, paper jams,..., how did you solve the problem? Did the service replace fixing film unit, or complete fixing unit? Do you have enough air flow around the copier, is the copier beneath the air conditioning device, is there any air draft,...?
If you want you can contact me on emma.servis@gmail.com, for more help.
Feb 24, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
1,448 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
