Question about New Balance 1400 Treadmill
Need a circuit board for new balance 1400 treadmill
  • 4 Answers
SOURCE: Our New Balance 1400 treadmill starts to slow
Please check wheel setting ( When calipration)
sada
Posted on Jul 13, 2009
erpaalai
  • 999 Answers
SOURCE: ERR 1 on NEW BALANCE 1800 Treadmill
It is on the circuit board, It is white or gray with silver on the ends and it will be about an inch long and tubular. eric
Posted on Dec 25, 2009
  • 218 Answers
SOURCE: new balance 2500 treadmill shows e1 code and keeps
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Posted on Aug 14, 2010
Mustgo
  • 2359 Answers
SOURCE: I have a New Balance 1400 treadmill (manufactured
The only weak spot on the main controller board is the small rechargeable battery or a lithium button cell.
The memory battery is to keep the parameter information.
When the battery is damaged the liquid (electrolytic) drips downward on to other electronic items.
Any items under the "drip" pathway will need to be inspected and clean.
The battery can be on the front or rear on the main board,
Spend some time to locate this battery,
A simple $12 item can stop the unit from operating!
Please email me the part number or spec, info on the battery on reply.
Posted on Jan 08, 2011
Joed911
  • 4338 Answers
SOURCE: I have a New Balance 1400 Treadmill. I turns on
I have a Horizon Treadmill that had the same error, it turned out to be a calibration using the adjustments on the logic board. The New Balance does not show the calibration procedure, but you can call 800-497-5831 for service. Hopefully it is still under warranty.
Posted on Jan 26, 2011
I have an older NB 1400 Treadmill (7 years old)
Motor controls for New Balance can be found by doing a Google search on Treadmill Analyzer and look for the MCB List page of repairs offered :-)
Jul 15, 2014 | New Balance 1400 Treadmill
Fan problems
this is indicative the some electronics components is in short circuit in the pcb. You must replace. However RUN the software calibration for diagnose, and fix it. see the block diagram.
you can measure the input voltage for the main motor if there are the motor is o.k and vice-versa
2) you can measure the output meassure from the pcb board is there are NOT the board is faulty for the input voltage motor.
Jun 05, 2013 | New Balance 1400 Treadmill
My New Balance 1400 treadmill recently stopped working. There is power going to the motor. The lights are on but there is no power to the display. nothing lights up and none of eh controls work. The...
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
May 09, 2011 | New Balance 1400 Treadmill
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
I can not get the treadmill to power on.
I have the same problem and have isolated it to the main console board. When you flip the main power switch, does the console display light up briefly and then go dark?
Aug 25, 2010 | New Balance 1400 Treadmill
I havea new balance 1400 I keep getting two error codes on my screen the first is E1 and then A E3 on elevation.?
Hi This is dinesh here,
The E1 Error is for the sensor problem and the E3 error is for the IC crasg in the machine...
Jul 22, 2010 | New Balance 1400 Treadmill
I have a 1400 that when it has been running for 20 or 30 minutes goes to Power Failure and generally throw me against the rail to an abrupt stop. I do believe it is home electrical as I run a 20 amp...
This generally means that lubrication is needed to be applied between the belt and belt. You may purchase these kits thru www.jadfitness.com the products name is Lube and Walk follow the instructions that come with it to apply the lubrication.
Jun 11, 2010 | New Balance 1400 Treadmill
Dec 24, 2009 | New Balance 1400 Treadmill
Tech support for New Balance 1400 treadmill thinks that motor stopped due to fuse on circuit board. Where can I get the fuses?
In general, I haven't ever seen the MCB fuse ever blow. But the fuse should be visable if you remove the lower cover and look at the circuit board, most of these are of the old style automotive type and can be found at an auto store. more than likely a transister is blown and the board itself needs to be replaced, this usually happens due to the deck not being lubricated
Aug 22, 2009 | Exercise & Fitness
Treadmill Won't Start
you need a new lower board from the mfg. you can replace this item you self if the make the part still call them.
Apr 18, 2009 | New Balance 1400 Treadmill
New Balance 1400 Treadmill Logo
60 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
