Question about Vacuums
Black and decker handheld vacuum phv1800 type 1 low battery power
Hello, i have had this vacuum for about 2 years, i hardly use it. and when i do i just noticed that i put it on hi then the power will slowly diminish in a short period of time. can you help me. please thankyou
  • jasmincsanto Jun 19, 2009
    hello, thankyou very much for the info, by the way i am in guam. thanx again. good day.
  • 328 Answers
Hi I know what you mean! My B&D dust buster used to do this too. The hi power boost means that it can only be used for a limited amount of time. Due to the age of the dust buster though its a sign that the battery is on its way out and regardless of whether or how long its been used or not used, batteries can lose power regardless.
Try to let the dust buster completely lose power and then charge it up for its initial burn in period of 14 hours. Also clean the connection metal strips or hole with a dry cotton bud incase there's any static or dust. Then see if it lasts longer. If the turbo mode or speed 2 is still short, then the battery is dying out.
I don't know where you are but in the UK its hard to get battery replacements for B&D products. You could check your local seller where you are if they have battery replacements but at the cost of current dustbusters it may make more economic sense to consider buying a new dustbuster.
Posted on Jun 19, 2009
Dust Buster 16.8v won't hold charge. Can you replace rechargeable battery or is it shot?
Posted on Sep 19, 2011
Weak suction
if you've changed filters and checked for blockages it may need a new suction fan ,,you can download the diagram off the link below
http://www.ereplacementparts.com/black-and-decker-phv1800-dustbuster-parts-c-4167_8887_8897.html
Mar 13, 2013 | Black & Decker PHV1810 Bagless Handheld...
PHV1800 nozzle fixation
yes i can see it, and according to that, heres my answer
you can try pulling harder.. or use the screwdriver as a lever... it doesn't make sense that if you unscrew everything, you cant pull it out, so maybe its something tats a bit stucked
Jan 08, 2008 | Black & Decker PHV1800 Bagless Handheld...
I cannot remove filter from Black and Decker PHV1800
yes you are doing it right it should only turn about 1/4 inch then pull out go to this link for manual and diagram it ma help you..
http://servicenet.blackanddecker.com/Products/Detail/PHV1800
Dec 18, 2012 | Black & Decker PHV1800 Bagless Handheld...
My phv 1800 doesn't have any vacuum power any longer. I have kept the filters cleaned and emptied. It is still under warranty. What can i do
Good afternoon,
There could be a few different problems with the vacuum, some more serious than others. The great thing is that the unit is still under warranty. My advice would be to contact your local B & D Service Center:
"All Black & Decker Service Centers are staffed with trained personnel to provide customers
with efficient and reliable power tool service. Whether you need technical advice, repair, or
genuine factory replacement parts, contact the Black & Decker location nearest you. To find
your local service location, refer to the yellow page directory under "Tools-Electric" or call:
1-800-544-6986 or visit http://www.blackanddecker.com/."
For further reference, please view a free copy of your manual here:
http://www.manualsonline.com/mdownloads/4fef4018-4fd3-48fc-a346-699c326a1b92.pdf
I hope this starts you out on the right foot. Please rate this solution!
Thanks,
~PCF
Mar 07, 2011 | Black & Decker PHV1800 Bagless Handheld...
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Is there a cheap battery replacement Black and Decker PHV1800
Hi pwolft...
Amazon offers pretty large number of black decker replacement batteries, click here Finally charging for our multi device world and pick one (which fits).
Hope this was helpful.
enjoy
Jun 13, 2010 | Black & Decker PHV1800 Bagless Handheld...
My brand new B&D PHV1800 handvac does not charge up after 1 use. Could the battery be dead already?
Hello and Welcome to FixYa!
This can be caused due to one of the following reasons.
Bad Charger or the Charging IC!
Dead or Weak battery.
Loose contact of charger pin with the socket.
If you have purchased a new unit, then you can go for a warranty claim in case the problem in not solved at user end.
Best of Luck,
Concerned,
Jun 03, 2010 | Black & Decker PHV1800 Bagless Handheld...
Won't recharge. very weak.
If you know that the charger is actually working and supplying the correct voltage.Then the age of the unit would suggest that the battery is exhausted and it would be cheaper to replace the whole unit.
Hope this was a help.
May 12, 2010 | Black & Decker CHV9600 Handheld Vacuum
PHV1800 nozzle removal
Here is an exploded diagram which seems to show that the whole nozzle assembly is removed as one piece.
See if it helps:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65223&typeId=14858&documentId=34001
Jan 06, 2008 | Black & Decker PHV1800 Bagless Handheld...
Vacuums Logo
868 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
