Question about Konica Minolta Great Minolta Spotmeter F Ambient/flash Photography
Disassemble minolta spotmeter f
Battery leak
New batteries and my minolta 7000 will not power up
Check for battery leakage on the springs n the battery compartment. That is the usual cause. You may have to disassemble the battery holder to clean it all out (use CLR to resolve the sludge and then clean it off).
Sep 30, 2014 | Photography
Minolta DiMage G500: objective does not retract
if it has a power but not responding, there's a problem on the mechanical that makes the lenses move forward. try to service it.
Mar 02, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Lens is stuck in the out position, can you help ?
yes it happens to me too.
please find the camera disassembly manual in pdf format or try youtube video.
then you can dissasemble cam and fix the stucked parts.
95 :/: is no damaged parts .you need to reassemble according to manual.
regards,
nuwan
Aug 20, 2014 | Konica Minolta DiMAGE E500 Digital Camera
Put new batteries it won't power on. been sitting not used for multiple years. bought new film but it doesn't seem to load since it won't power on. minolta qt si camera
Did it sit for years with batteries in it? You may need to clean corrosion off the battery contacts. Even alkalines and rechargeables can leak.
Oct 22, 2010 | Konica Minolta Maxxum QTsi with 35-80 lens...
Rplacement battery door
the battrery door if still connected you can use a small strip of crome duct tape it blends in with your camera . close the door the best you can and tape it! good luck
Aug 23, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Hello, I have a minolta spotmeter F and the backlight isn't working, please help.
Unless you know someone who is quite handy with equipment like this you should probably send it in for repair. Do you have a copy of the owner's manual? If you don't, I found a website that has it available as a download for a reasonable donation fee of $3. His URL is as follows:
http://www.butkus.org/chinon/minolta/minolta_spotmeter_m/minolta_spotmeter_m.htm
As for the repair you'll need to contact Sony. They have taken over support and repairs of all Konica-Minolta photographic equipment. Their URL is as follows:
http://eservice.sony.com/webrma/web/index.do
Feb 28, 2008 | Cameras
Disassembly lens konica minolta Z3 Z5 Z6
I think the manual of this sort are not available to the general public or indeed the 'trade'
You will have to grope your way if you want to play those games
Feb 23, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Konica Minolta Great Minolta Spotmeter F Ambient/flash Photography Logo
64 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
