Question about Precor 956i Experience Series Treadmill (Used)
I need a motor controller for precor C956i - Precor 956i Experience Series Treadmill (Used)
4 Suggested Answers
  • 218 Answers
SOURCE: The quick start button does not do anything,
You would need to replace the keypad overlay on the console.
Posted on Aug 13, 2010
  • 1833 Answers
SOURCE: I have a Precor c956i
Removethe red "STOP" cover. The cover may pushes against a switch. If theswitch moves too far down and rests against the cover, it will be stuck in alock position causing the error message. To remove the red STOP cover, removethe few screws behind the console. When the front cover is off, turn it overand unscrew the two screws that hold the red stop cover. Then push the coverout through the FRONT. Do not attempt to lift it out by the end with the screwholes. It will not pull out that way. Test the machine before screwing thepanels back again. The message should no longer show STOP KEY. Test the visiblewhite small switch that you uncovered by removing the red flap. The messageshould stop when you press the switch. If theproblem still exists then open the console and check under the magnet holderfrom inside you may see rust ire broken cable there, if you find thisthen you may have to replace it. Hopethis will help you.AV
Posted on Jun 11, 2011
  • 966 Answers
SOURCE: Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Posted on Dec 13, 2013
Dec 13, 2013 | Precor C956i Treadmills with HR /...
I have a precor c956i and got error 27 on it, what can i do to resolve probmem? thank you
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Sep 27, 2013 | Precor C956i Treadmills with HR /...
C956i Precor is displaying Error code 44 ?
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
May 30, 2012 | Precor C956i Treadmills with HR /...
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
Noisy precor treadmill motor
that sound is due to the bearing failing inside the motor this is cause by capacitance discharge thru the armature thru the bearings. these unit can be rebulit I 've done plenty
Apr 13, 2010 | Precor C956i Treadmills with HR /...
???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Apr 27, 2009 | Precor C956i Treadmills with HR /...
Precor 956i Experience Series Treadmill (Used) Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
