Question about Apple Black Iphone Model A1241 8gb
Dispely photo apple no start - Apple Black Iphone Model A1241 8gb
I receive the error "Missing
Put an EndFor command 2 lines down from the For j,1.n/2 line. Right above y1(p) store p. You'll have to have a 0 store p inserted into the program or, you'll get a circular error. I put mine right under input n. Also where you store 0 in s and v.
Jan 19, 2011 | Texas Instruments TI-89 Calculator
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Dec 14, 2010 | Insignia NSDSC10A Digital Camera
The view screen in the back oc camera has stopped working.It only works when reviewing photos taken. Can anything be done?
Think that you might have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 03, 2010 | Canon PowerShot SX100 IS Digital Camera
LCD doesn't work when in photo mode. Can view pictures already taking, but the LCD does not work when trying to take pictures
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jan 17, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
The soap dispenser won't lock closed--where can I get a replacement? do I need a repairman or is it something I can fix myself?
you can get a new disp from american appl in denver . they have a web sight . / replace the complete disp . they do not repair very well./ can you do it yourself ?? probably can its about 1/2 hr job and fairly easy . do not force disp when installing but do press it in firmly .. **** .. hope this helped .
Dec 18, 2009 | Bosch SHU3305 Dishwasher
My playback function is not working. There seems
hi, sometimes even when the play back function is working you wont be able to see it due to the DISP button. canon has one disp button in lower right hand corner. when you are in play back mode, press the disp button three times. at any one point you must be able to see the photos. else revert back to us. thank you dewan
Oct 18, 2009 | Canon PowerShot A630 Digital Camera
Camera picture not shown on screen
It could possibly be because after selecting the "disp." (display) button several times the screen goes black. Simply press the "disp" button until you monitor will show what your camera see's.
Oct 31, 2008 | Canon PowerShot A410 Digital Camera
Black screen
Did you try pressing the DISP button while trying to take pictures? It turns the display on and off.
Nov 20, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Apple Black Iphone Model A1241 8gb Logo
10 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
