Question about Hobart Welding Tools
Wiring for 220 - Hobart Welding Tools
    New Friend:
    Problem Solver:
  • 19 Answers
Http://fileshare.eshop.bg/download_start.php?downloadurlid=62919
Posted on Nov 12, 2014
Wiring diegram
should come wired for 220 volts one of the hot wires and the other colored or black wire should get 220 between them from each to ground 120 volts 1st hot to L1 2nd hot to L2 green to ground or case
Feb 10, 2018 | Smith Pool & Spa
Wiring diagram for sx model
look on the side of the motor it has a diagram for both 240 and 120 if wiring 220 motor should already be wired if 120 volt you have to move the wires shown on diagram
Aug 27, 2014 | Pool & Spa
220 volt wiring diagram
You might be able to get a diagram from Rockwell or the motor manufacturer.
May 19, 2014 | Rockwell 10" Table Saw with Leg Stand 13...
220 pulsar wiring diagram
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
2007 Bajaj Pulsar 220 DTSFi wiring diagram Google Search
Bajaj Pulsar 220 DTS Fi Owners Club RETIRED
Service Manual Bajaj Pulsar 220
http://www.tunasmegaspirit.com/files/catalogue/Pulsar-220-Spareparts-Catalogue.pdf
https://www.facebook.com/media/set/?set=a.504541669580494.120586.177568422277822&type=3
Sep 25, 2013 | 2007 Bajaj Pulsar 220 DTSFi
Wiring diagram for aosmith a48a93a66 motor
Label will show wiring diagram.
Usually: L1 Line 1 will be 120V Hot
L2 Line 2 is Neutral
Low voltage is 115 volts
High voltage is 220 volts
Motor shipped new with 220V default
Compare existing wiring to what appears on label.
Label will show wire colors Brown, yellow, red, white etc.
Move these wires as needed to change voltage.
Take photo of label, post on internet, add comment with link to photo so diagram can be viewed.
Nov 08, 2012 | Pool & Spa
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Welding Tools Logo
32 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
