Kenwood tuner t74l - Audio Players & Recorders
How do I reset am and fm channels on a kenwood stereo synthesiser am/fm tuner kt-57?
Trisha, I beleive you use your autoscan feature, when it stops on a station you want to keep press and hold one of the preset buttons.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Keenwood KT 57 digital tuner
ORIGINAL OWNERS MANUAL FOR KENWOOD KT 57 TUNER0 results You may also like
Jun 25, 2016 | Kenwood Car Audio & Video
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Mar 25, 2016 | Kenwood KT-57 Stereo Synthesizer AM/FM...
Locating part No. FIP12PM7 for a KT88 Kenwood Stereo TUNER
There are sites on the internet that specialize in parts for "vintage" audio gear. Check them out. Of course, if you can get the generic part number (for discrete parts, not boards and assemblies) that would be better and cheaper.
Oct 28, 2015 | Kenwood Car Audio & Video
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Need to use Aux function with Satellite Tuner installed.
Yes, you will need to consult your owners manual (if you don't have one try Kenwoods website). AUX functions are turned ON during initial setup (like when you set the time).
Mar 13, 2009 | Kenwood KDC-MPV619 CD Player
Kenwood kdc516s, cd audio does not work, it can be inserted and removed, it shows track information and elapsed time but there is no sound, is there a fix?
If your car has a factory amplifier, you probably tied the kenwood's antenna turn on lead (blue) with the factory amp turn on wire. That bue wire only supplies voltage when your source is tuner. you need to use the kenwood' amp turn on (blue/white) to get the factory amp to turn on with the cd player and the tuner
Dec 03, 2008 | Kenwood KDC-135 CD Player
Kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. kstahl65@att.net
Feb 24, 2008 | Kenwood KVT-715DVD Car DVD Player
13 people viewed this question
 Grubhead
Grubhead
