Question about Iview Cyberpad 756TPC Tablet
Not charging its only charging when i put the charger at at a certain angle if i dont it wont charge
I have a dragon touch tablet but its not charging. I have to put force and hold it for a long time at a certain angle
Sounds like a bad charger port. If possible find a friend that has as 'like' tablet and see if that charger will work. I don't know of any device that needs to be in a certain position to charge. Since it's charging at an angle and with pressure, then it's probably not the charger, although it could be the part (of the charger cord) that you put into your tablet, usually from a high number of insertions/retractions or abuse.
May 10, 2015 | Dragon Touch Tablets & eReaders
Tablet doesn't turn on, it shows a battery with an triangle and this symbol!
When you have the charger plugged into the tablet and wall outlet does the triangle change to a lighting bolt if it doesn't change try a different changer either the charger or charging port or charging cable might be bad
Dec 31, 2014 | Tablets & eReaders
Tablet charger is 400mAh and Tablet battery is 4000mAh. is my charger sufficient ?
The charger is right for the battery. IF battery won't charge on it proper charger, the battery or charger is bad. Take it back or put out more $$$$$$$$$.
Aug 31, 2014 | Tablets & eReaders
My tablet wont charge what can I do I try to plug in charger but won't charge the battery even bought another charger still dont help
Most likely you are using an aftermarket charger. You may want to purchase another or buy and OEM charger.
Jul 09, 2014 | Polaroid 4.3" Internet Tablet
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Kurio tablet wont turn on
1) do you get a charge light?
2) Do you have to hold the charger on an angle to charge
3) Has it been dropped?
If yes to two or more of these questions it sounds like you need to bring it in for service. You can bring it in directly to our shop for a FREE evaluation or send it in for repairs... sounds like it either it has been shocked through a surge or drop and/or charge/DC jack is damaged.
Thanks,
Rising Son
Jan 31, 2014 | Kurio Touch 4S Handheld
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Lepan wont come on after charge how to reset
That is very common with Le Pan.
If yes to two or more of these questions it sounds like you need to bring it in for service. You can bring it in directly to our shop for a FREE evaluation or send it to Le Pan for repairs... sounds like it either it has been shocked through a surge or drop and/or charge/DC jack is damaged.
Thanks,
Rising Son
Mar 21, 2013 | Tablets & eReaders
How to reset the lepan wont come on after charge all day
Thanks,
Rising Son PC Repair by The Rising Son
Iview Cyberpad 756TPC Tablet Logo
23 people viewed this question
Top Iview Tablets & eReaders Experts
 Mikey
Mikey
Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
