Question about Xerox 6500/N Phaser Laser Printer
Error code 042-372
Besides turning on & off the printer, 10 sec wait period, What do we do to fix this code?
2 Suggested Answers
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
Error code E000000
ConditionThe temperature of the fixing unit does not reach thetargeted temperature -10 deg C within 63 sec. afterthe wait sequence is started.CauseThe fixing film unit is faulty. The engine controllerPCB is faulty.
- Replace the fixing film unit.
- Replace the engine controller PCB.
http://www.smoothprinterservice.com/
Dec 26, 2012 | Canon LASER SHOT LBP 3300 Printer
Error Code E000002-0000
E002A start-up fault is detected under any of the following conditions of the main thermistor (start-up detection fault):
after exceeding 40°C, it fails to reach 60°C within 10 sec.
after exceeding 60°C, it fails to reach 80°C within 10 sec.
after exceeding 180°C, it fails to reach 195°C within 10 sec.
Jan 19, 2010 | Office Equipment & Supplies
Konica minolta d183 error code C0000
Main motor malfunction.Change the main motor and check the fusing unit.For reset turn OFF and ON the power switch,unpluged the cords and wait 10sec. pluged on and then ON the power switch.
Oct 22, 2009 | Office Equipment & Supplies
Cs580 error
Check the exhaust fan motor,and reset the error code by turning OFF the main switch wait 10 sec and turn ON.
Oct 02, 2009 | Gestetner DSm615 Digital Imaging System
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Lexmark C772n - 127.07 Service fuser error
I searched the Technical Manual and there is no explanation of the code. The user manual simply says there is a printer failure. They ask that you turn the printer off, wait 10 secs and then restart. Then call 1-800-LEXMARK and they will tell you about the code.
Given that your printer is saying Service Fuser, it is highly likely the fuser is ready for replacement. The fuser is the component that heats to high temperature to fuse the toner to the paper and complete the print cycle.
Aug 12, 2009 | Lexmark C762 Laser Printer
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Error code on 5300 printer
turn off the printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Xerox 6500/N Phaser Laser Printer Logo
87 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
