Question about Saeco Royal Professional Espresso Machine
How to grind beans - Saeco Royal Professional Espresso Machine
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
When machine grinds coffee it makes winding noise but does not grind coffee, hence you get water
This is a desgin flaw of this machine. Hapens when you use the machine over a long continous period. The water damp makes the grinder wet a it cakes up. The spring is supposed to remove the debris but does not work well. Remove beans form bean tray. Remove the bean tray (1 screw and pull the knob off). Use a vacuum cleaner to **** out the wet bean grind. Dry the wet damp area and use a tooth pick to remove the bean grind (especially around the scute). Let dry and assemble, Good luck!
Aug 09, 2010 | Krups Small Appliances Espresso Machine
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 27, 2009 | Coffee Makers & Espresso Machines
Beans are too oily
Aug 06, 2009 | Bosch Benvenuto B30 Espresso/Coffee Maker
Spinning but not grinding
Dec 08, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Professional Espresso Machine Logo
12 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
