Question about Electronics - Others
Rewire electric soldering iron - Electronics - Others
2001 vw passat, water leak in from sunroof. went on ebay bought used comfort control module, and part of electrical harness. rewired 2 connetors useing soldering iron and heat shrink tubing. car start
https://www.youtube.com/watch?v=Hbr77jfWwOk
Sunroof drains are a common problem on many models. Cleaning or modifying the sunroof drains usually takes care of the problem. You may resolve your problem. I believe that the trouble codes are unrelated and may need professional diagnosis as you need VAGCOM to adapt the throttle.
Jan 30, 2015 | 2001 Volkswagen Passat
THE WIRING ON THE KICK START SWITCH HAS BROKEN HOW DO I REWIRE IT??
KICK STARTS DON'T HAVE A SWITCH
that's why its a "kick" start. You rewire an electrical start with a soldering iron, heatshrink, and by matching up the wires.
Sep 28, 2014 | Yamaha Motorcycles
Where can find cheap price china 40w Electric Soldering Iron with 7 pcs welding tool
eBay is the place to get cheap China soldering irons.
I have no idea as to what you're talking about when you ask about a 7 pcs welding tool.
Welding and Soldering are two different things.
Jul 26, 2012 | Weller Welding Tools
Got a question for the community, i am looking at buying a sodering iron, for working on cb radios and i have found one that seems to fit the bill and my pocket book, it is a 40watt pencil tip sodder
40 Watts is pretty powerful and will do what you need. However if it doesn't have any temperature control it may be too powerful. I use a 25 Watt electric soldering iron and it does everything I ever wanted in electronics. The danger of using an iron that is too hot is that it could heat components and solder beside where you want the heat.
If it's a gas operated soldering iron it's probably ok since ratings on gas irons are only estimates. Gas soldering irons are handy for working away from mains power, like in your car, however many of them tend to work great when new but after a few months they start to run out of gas very quickly probably possibly because they develop a leak. If you're only buying one I'd say get an electric 25 Watt one.
Feb 28, 2012 | Welding Tools
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
How hard is it to rewire a 2006 stratliner? A rat chewed up some of the wires in the bike and it wont start.
slice open the wiring loom where the rat chewed them and rejoin them with a soldering iron, use heat shrink over each wire to insulate, the wires are all color coded, so should be an easy fix.
Mar 12, 2011 | 2006 Yamaha Stratoliner
I just bought the soldering gun but the instructions on the package aren't very useful how do i use the gun?
A soldering gun is used much the same as a soldering iron for melting solder mainly to connect electronic components to circuit boards. To use it you plug it into the electricity mains and press the trigger. This causes the metal tip to heat up. Allow a minute or so for it to reach full heat and press it to the components you want to solder together. When they heat up press the solder against them. The solder melts and runs on and between them forming a bond. Remove the soldering iron and release the trigger. Once the trigger is released the gun starts to cool down again.
If you've used a soldering iron before you'll probably find the gun more awkward as it cools down every time you release the trigger. It's really only useful for quick jobs where you're not going to need it every few minutes. For other jobs where a lot of soldering is involved a soldering iron is better. The advantage the soldering gun has over the soldering iron is that it heats much faster for quick jobs.
Dec 04, 2010 | Cooper Industries Weller 7200PK 75 Watt...
Rewireing a handle
black goes to gold white to silver well guess you know where green goes now
Jan 04, 2009 | Weller TC201T: Soldering Iron For Wtcpt,...
Soldering Question
# Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the iron. The iron should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot iron and there is a serious risk of burns and electric shock. # Always return the soldering iron to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
Aug 27, 2008 | CRL Soldering Iron Temperature Control
Electronics - Others Logo
74 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
