Question about Neff V4380X0 Front Load Washer / Dryer
Error codes Neff Auto
Starts to fill and in a few seconds shows E11 on display
  • nomanual Sep 01, 2008
    Starts wash cycle then stops full of water with Anti-Crease light flashing and "1" displayed in led panel.  Both flashing at same rate.  Cannot find machine model number and only a copy of instructions in NL or F ... seems like the pump may need cleaning?? from what I can make out in these manuals.  How can a supplier not have user manuals on the web?
  • Anonymous Feb 08, 2009
    I have the same issue- NEFF say E11 is a "comunication problem". Guy came out and said it could be the motor although note 100%. Will need to cough up for a new one to see if the problem is sorted.
2 Suggested Answers
fanny
  • 146 Answers
SOURCE: Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Posted on Nov 04, 2007
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Wa75t65gw1
After 2 minutes does the machine throw up an error code. Starts beeping and shows a weird pattern of lights?
If so that error code can help us diagnose what your problem is.
If it does give you an error code take a photo and post it back on here so I can see what it is.
Jul 04, 2017 | Fisher and Paykel Washing Machines
WHAT does E11 meens washer does not take in water
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF705BZHS, is not filling with water and showing an E11 error code. The E11 code means that your washer is taking a long time to fill. First, make sure that the incoming water faucets are turned on. Next, you will want to make sure that the pressure is above 30 PSI. I suggest resetting your washer, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire AFFINITY WASHER ATF705BZHS FOR...
I installed a new control panel in my Frigidaire dryer and it displays E11. Is there anything I can do to clear this code?
Hi Steve, thank you for your question!
Generally, error code E11 means that it has detected an internal checksum error or processor error. First check to see if it is a false error code by resetting the power to your dryer by either unplugging it or flipping the household circuit breaker for about 30 seconds. If the error code persists, your dryer may have a faulty main control board. Regrettably, this is not a simple DIY job. It is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best of luck!
Feb 02, 2014 | Frigidaire Dryers
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
Zanussi washing machine error codes 1 red flash and then 1 green flash
Hi there Yovanah:
Reds and greens on the start LED in a recurring sequence (unless you have an LCD display in which case the error code is displayed on screen).
Red flashes are the first digit in the error code, green the second. i.e. 5 reds, 2 green, then pause = E52. Which indicates a fault in the drive train...motor, motor capacitor, wiring, or pcb. Error codes are far from foolproof...on the contrary they can be directly misleading at times. But invalid error codes are almost always an indication of a defective pcb.
According with your code, E11 = Problems with water fill in wash phase (maximum 10 minutes for each fill phase).
Possible causes:
1: Tap closed
2: Mains water pressure insufficient
3: Solenoid valve
4: Hydraulic circuit of pressure switches
5: Pressure switches
6: Wiring 7: Main PCB
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Washing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
Neff V4380X0 Front Load Washer / Dryer Logo
1,208 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
