Connecting an ITT Tricon
This turntable is quite unusual on the market and the problem is that it has an even more odd connection. Some kind of 11 pin plug should be fitted and no one has ever seen something like this. Without a cable it is not possible to use ant it is a pity due to it is a nice looking unit. What I need is a cable to get it to work. I have a wiring diagram but Iam not the one to solve things with that.
  • 515 Answers
SOURCE: Connect turntables(technics SL1210MK5) to a mixer?
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
SOURCE: Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Posted on Dec 31, 2008
  • 104 Answers
SOURCE: I need a grounding wire to connect to my Griffin Imik
not sure I fully follow your question but the 3 rd ground wire from the turntable would hook up to the ground screw on the imic
Posted on Feb 11, 2009
  • 89 Answers
SOURCE: Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Posted on Mar 13, 2009
  • 104 Answers
SOURCE: Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
Posted on Apr 17, 2009
I think your SOL dude as those types went out a long time ago and were proprietary.
Apr 18, 2014 | Audio Players & Recorders
Pluging in a turntable
I dont understand why you would want to connect a turntable into your phone. Can you explain?
Mar 30, 2008 | Audio Players & Recorders
I have an Aiwa PX-E77U turntable I'm connecting to a Pioneer VSX-454 receiver. The turntable has no ground wire. It plays okay at low levels, but as soon as I bump up the volume a little, I'm getting a...
It could be a bad connection of the earth pins to the cartridge. One turntable I had hummed even with an earth connection. I found out that the cause was the connection of the earth wire in a 3 pin plug.
Aug 31, 2013 | Aiwa Audio Players & Recorders
How to connect power switch to mother board
Click on -
Intel Desktop Board DG41RQ Product Guide - English (PDF)
Bookmarks menu to the left -
1) Click on the + sign to the left of -
1 Desktop Board Features
Click right on - Desktop Board Components
Or go to Page 11. (Adobe Reader page number box at top)
Front Panel header location marked by P, in the figure.
2) Click on the + sign to the left of -
Connecting to the Internal Headers and Connectors,
in the Bookmarks menu.
Click on - Front Panel header
Motherboard mounted in computer case, the Front Panel header is in the bottom/right corner, above the top black SATA connector.
Two rows of contact pins.
The Top row is numbered EVEN.
Starting at the Left side going across to the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
The Bottom row is numbered ODD.
Starting at the Left side going across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Probably 5 Volts DC for factory testing.
D) Pins 2 and 4 are for the Power On LED. (Light)
This IS for a -> 2 wire LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
To the left of the Front Panel header is a 3-pin header.
This is the Alternate Front Panel LED header.
If you have a -> 3-wire LED, it connects here.
Also wanted you to have the motherboard manual.
Nov 04, 2012 | Intel DG41RQ Motherboard & Core 2 Duo...
I have 9 wire from my front of my case &2line USB in the names are SHIELD/GROUND1/GROUND2/-D1/-D2/+D1/+D2/ +5V1/+5V2 & Ihave 9 socket on my mainboard IWILL P4S from plug in the wires there are...
Refer to the drawing below and I will explain the connections. You have the nine wires as you described. First, you will not be connecting the SHIELD to anything, so set it aside. Now, the remaining 8 wires are split into 2 groups of four. You have +5V1, -D1, +D1, +GROUND1 on the first group. These wires will attach to the ODD pins 1,3,5,7 respectively (see the chart next to the drawing). Use the missing pin location to orient yourself to the EVEN and ODD pins. The remaining wires +5V2, -D2, +D2, and GROUND2 will go on the EVEN pins 2,4,6,8 respectively.
Hope this helps!
Jan 07, 2012 | Computers & Internet
When i hook up my B &O turnable to Audio 1 Or Audio 2, i got sound but at very low volume even when jacked up to max. all other components blast out audio from my speakers.
It's logical, the audio output level for the turntable is very low (depending on the model about 1-5mVolts) while the line inputs (where you try to connect the turntable) can handle audio levels of 500-775mVolts. As I can see your amplifier is not able to handle this kind of inputs (assuming that your turntable is a typical one, without any include preamplifier) In case you insist on connecting this turntable on this amplifier there are some solution to suggest (mainly using a kind of pre-amplifier between the turntable and the main amplifier) but in order to be sure for what to suggest to you, please clarify me the brand / model for this turntable.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
Feb 05, 2011 | Yamaha RXV367 Receiver
Hi I have a Technics SL-350 Turntable System that I bought at a tag sale today. It turns on properly, spins, and you can even slightly hear the sound of the music while it's spinning. However, there is a...
plug a red and white rca cable into the back of the turntable and then plug the other end into your phono output at the back of the amplifier.then turn your selector on your amplifier to phono.wowla you should have sound
Oct 17, 2010 | Technics Audio Players & Recorders
9999555533331111 out of these numbers any 6 numbers total is 21? how
this would be explained on the basis of two FACTS below.......
sum of two odd numbers are always even and
sum of to even numbers are also always even
then how 6 odd numbers (consider 3 pairs, 9 5 3 1 being odd numbers) can make an odd number 21..!!
Make your basics strong...
Aug 14, 2010 | Computers & Internet
Meaning of Db and the use of Db9-male Cabl
The D is the shape of the connector when looked at it on it's side. The second letter (A,B,C,D,E) defines the amount of pins in the D connector. "DB9" is actually called DE by the standard and the E=9 pins. A=15, B=25, C=37, D=50, E=9. This standard was set in place by ITT Corp (Not the school) in 1952, and DE-9 connectors were used for tons of applications. (Machinery, Cars, etc). If you are only referring to the computer uses, the connector is widely known as RS-232 or a "Serial" port. These ports in computers were/are used for devices like early printers, scanners, networking hardware, or even as a method of connecting to the Internet at one point.
Dec 05, 2008 | Parallel 6 Foot DB9 Male - DB9 Female Null...
98 people viewed this question
