Question about Maytag Dryers
Pen exploded in my dryer and now it smells like fish. How do I get the fish smell out?
  • 66 Answers
SOURCE: Bad smell inside dryer
you might want to vacum the lint filter and the all the fan blower area some thing in the dryer is dead .
Posted on May 10, 2008
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
  • 62 Answers
SOURCE: My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Posted on Jul 09, 2009
  • 10 Answers
SOURCE: Stain in dryer
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Dan
Posted on Aug 06, 2009
  • 221 Answers
SOURCE: When drying clothes in my gas dryer, you can smell
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Posted on Jan 17, 2010
Brand new Amanda dryer and it smells like fish. Can you give us some idea why
This sounds like it could be a unit that was flooded with stale water. This is often seen after major hurricanes or flooding, such as we saw in Houston recently.
Oct 18, 2017 | Dryers
When dryer is on there is a smell of catfood/fish while clothes are drying.
Move dryer and look for cat food/fish under or behind. The heat may be activation the order.
Jan 14, 2015 | Siemens WT46W568GB Condenser Tumble Dryer,...
Refrigerator smells like fish
Put a couple of boxes of baking soda in the fridge to absorb the smell.
Apr 18, 2017 | Thermador Refrigerators
Frigidaire dryer smells fish odor
well then clean your fish in the sink... or check for a leak and you might find some mold
Dec 30, 2013 | Frigidaire Electric Dryer
How to get fish smell out of dryer
Tomato juice removes skunk stink from your dog, maybe put some on a towel & run it through a cycle.
murf427
Aug 01, 2012 | Whirlpool Dryers
Fish smell in my car ac vent
ok dead fish smell is also caused by car being in a flood and car dealers not telling anyone its a lemon!!!!! Got proof!!
Jun 02, 2012 | 2004 Dodge Neon
Burnt fish smell in microwave
Mix vinegar and water in a small container, set timer for 60 seconds and start the microwave, when it starts to steam it will bond to the interior, at that point dis-engauge microwave oven, if smell is still present open a small box of baking soda let sit for 24 hours in the oven before use.
Jun 02, 2012 | Panasonic Microwave Ovens
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The lint trap on my dryer is moist.
I don't know what's causing the smell, but the moist lint trap and the "takes two cycles" sounds like the exhaust vent is partially blocked.
You can ask the apartment manager to clean it out, or you can take a stab at it yourself with an electrician's fish tape, a plumber's snake, or a dryer-duct cleaning kit. (I picked links from Ace, but you can get them at any hardware or home shop)
Pull the dryer out and detach it from the ductwork. If you're using the fish tape or the drain auger, then you'll want to tie a rag to the end -- washcloth to dishtowel sized at the biggest -- to wipe the lint out of the ductwork. If you've got the duct-cleaning-kit, then use the brush that comes with the kit.
Work your way up and down the ductwork as far in as you can reasonably reach. Chances are good that you'll soon have a huge pile of lint on the floor, and much better airflow through the ductwork.
Hook up the dryer and things should go much better on the next laundry day.
Aug 03, 2009 | Whirlpool LER5636P Electric Dryer
Stink-ola!
I would call out Maytag as it looks as if an insulator on the motor is burning out.
Or a connector is overheating
Get it checked in case you have a fire
Jul 30, 2009 | Electrolux Refrigerators
Dryers Logo
11 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
