Question about Philips CDR796 2-Disc CD Recorder
Trays keep opening
The trays on my Philips audio cd player/recorder CDR 796 recorder keep opening I will not stay close
SOURCE: Trays locked
Hi, I had the same problem and i found out that if you hold down the fast forward and the rewind buttons with the power on and off button it will reset. It took me a couple of goes but after a while it worked. When you do it keep all of the buttons held down and a series of numbers flash for about a minute then it will reset. Good luck, Jeff.
Posted on Jan 14, 2007
remove the tray out & put the grease on gears under the tray
Posted on Apr 05, 2007
  • 112 Answers
SOURCE: "TRAYS LOCKED" What amI to do?
http://www.fixya.com/support/t124205-trays_locked
search harder next time?
Posted on Nov 15, 2007
SOURCE: Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Posted on Jun 17, 2008
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
Broken disc tray
Hello,i have a problem with my Philips CDR 770 CD. .. I purchased lately on the internet 10 CD digital audio VERBATIM,but will not read them ... only reads the Philips digital audio,writable and rewritable,the repurchase ... I hope you can solve my problem ... THANKS
Mar 22, 2014 | Philips CDR770 CD Recorder
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
How do I finalise a cd on philips cdr 796
how do I finalise a recording , nobody has posted a solution , so the answer is press the record button
Dec 11, 2010 | Philips CDR796 2-Disc CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Question
I am 99% certain that it will only work with 'audio' discs. This is the case with my Philips CDR-796 and as far as I am aware applies to all consumer CD recorders.
Hope this helps
HifiJohn
Jan 04, 2009 | Teac CD-RW880 CD Player / Recorder
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Not reading blank cdr audio disks to record onto..
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Dec 12, 2007 | Philips CDR600 CD Recorder
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Trays locked
Nov 15, 2006 | Philips CDR796 2-Disc CD Recorder
Philips CDR796 2-Disc CD Recorder Logo
78 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
