Question about Miele T9800 Electric Dryer
How to I clean out the filter/vent
The dryer is overheating and stops. Vent is full and needs to be taken apart to clean
cpldw48
  • 131 Answers
SOURCE: got a software update and now dryer is flashing all indicators
try turn power off to dry,if still not working call the tech back that did the software update
Posted on Apr 25, 2010
ginko
  • 19396 Answers
SOURCE: I just had the softwear
Hi.
Try holding down reset for several seconds. If that does not work, then there is a problem with sensitivity settings of the signal from the two sensors in the air duct. Call Miele and insist to get a tech at home, the problem is not your fault.
Here a discussion on the same issue.
Posted on Sep 10, 2010
heatman101
  • 43501 Answers
SOURCE: Hi, The clean air vent light came on and shut the
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
heatman101
  • 43501 Answers
SOURCE: Miele T9800 dryer starts then stops and goes dead.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 19, 2010
  • 3074 Answers
SOURCE: check filter/vent lights are on. we have cleaned
there is a sensor below the lint screen, it has two screws, and this may have a film on it from the dryer sheets. The easiest and safest way to clean is take it apart(the dryer) gently/lightly wipe the sensor off. Be careful not to damage it, Good Luck Tim
Posted on Jan 16, 2011
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
Lint all over clothes
when was the last time you cleaned out the dryer and the vent line?next time send the brand name and model number off of the machine,just cleaning off the lint filter isn't good enough,you should have the dryer taken apart,clean the duct that the filter slides into,vac out the cabinet where the motor is and if the vent line is a long run from the back of the dryer to the outside you can remove the vent line from the back of the dryer and blow it out with a leaf blower,as long as there isn't a cage or anything on the outside hood stick the leaf blower in the vent line and blow the lint outside,also while you have the vent line off the back start the dryer and make sure you feel air blowing out the back of the dryer,if it doesn't you could have a problem with the blower wheel the dryer should be cleaned out at least once a year if it's gas and once every 1 1/2 to 2 years if it's electric.hope this helps and good luck with your dryer.
Jan 05, 2012 | Dryers
Duet f70 erroe
An F70 error is indicating that an overheating condition has been sensed.
Causes:
1. Lint build up at the outside wall vent flapper (Clean and Vac)
2. Lint build up in the dryer ducting (Clean and Vac)
3, Poor Air Flow through the dryer due to a blower wheel problem. (Broken blower wheel fins or the venter hub fails causing the blow wheel not to turn at full speed.
4. Lint filter is clogged with fabric sheet particulate. Wash it with vinegar and water and then soap and water.
5. Lint filter cavity is full of lint. Use a folded wire coat hanger to reach the inaccesable areas to dislodge lint build up.
This error is always caused by poor air flow. The dryer vent external connection should push a relaxed hand gently away from the dryer vent connection of the dryer. If you do not have this type of air flow you need to find out why.
Thanks for choosing FixYa,
Kelly
Sep 17, 2011 | Whirlpool Dryers
The dryer flashes the minutes and then cL and it says to clean the filter. It is clean but it wont turn on
It say to clean filter because it senses poor air flow so if filter clean the air flow is restricted,that could be caused by a restricted vent or espically in ge dryers the filter/blower housing is built up with lint and needs to be taken apart and cleaned
Jul 28, 2011 | GE Dryers
My danby is not working to its full potential it take two loads to dry anything what shoul i be looking for i know it might be the element but is there any other problems i should be looking at
restriction in venting, remove the vent tube and run a load, if it drys well then the vent tube is restricted, if not then the dryer will need to be taken apart and cleaned inside from the lint screen down. Hope this helps Tim
Oct 30, 2010 | Danby DCD5505W Electric Dryer
Kenmore gas dryer will not start after drying a couple of loads, but will restart after letting it sit for about an hour.
sounds like the motor is overheating and probably needs to be changed out.when was the last time you cleaned out the dryer and how old is it?the dryer should be taken apart and cleaned out once a year if it's gas and once every two years if it's electric.there's an open flame in a gas dryer and i've seen the lint catch fire in some of them.you should clean out the outside vent,if the vent line is a long run from the back of the dryer to the outside vent i use a leaf blower to blow out the line,clean out the duct that the lint filter slides into and with a shop vac i blow out the motor and vac out the cabinet where the motor is and blow out the gas tube,the lint builds up on the dryer motor,overheats it and all the oil in the motor dries up,you can see it on the back of the drum and around the motor,you'll see lint stuck onto the back of the drum stuck in the oil and like a yellow stain on the frame and wall where the motor is and the motor starts overheating and cuts out when it gets hot,when it cools it will start again but one of these times it wont start at all.sometime you'll hear a loud buzz when you try to start it.the motor is easy to change,you need to decide if you want to put money into the dryer or change it out,good luck
Aug 14, 2010 | Kenmore 63942 Dryer
Burning smell
Stop using the dryer! You are probably close to having a fire if you continue to use it. The whole vent system should be taken apart, cleaned, the heat limit sensors checked and the duct cleaned. Your dryer is overheating and is a danger.
Aug 11, 2009 | Dryers
FDE436RES1 - Frigidaire Overheating
tstat possible but make sure vent is open completely to outside ..may try load with rear hose off to verify
Apr 24, 2008 | Dryers
Miele T9800 Electric Dryer Logo
43 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
