Question about Ingenico iSC250 Payment Terminal
How do you access f4 - Ingenico iSC250 Payment Terminal
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
Jul 25, 2012 | Texas Instruments TI-84 Plus Calculator
Fn+F4
If you are using hibernation mode it causes all kinds of problems, not working, corrupting window files so you are forced to do a fresh install. The reason is windows needs to be properly shut down, other wise it will become unstable to the point you won't be able to access files. I strongly reommend to disable this function or at the very least make a backup recovery disc.
Apr 12, 2012 | Acer TravelMate Computers & Internet
How can i write a questionmark and a collum sign in the program utility on my calculator?
In Run Mode Press [SHIFT][[VARS] to access (PGRM)
The ? is entered by pressing [F4]
To get : press [F6][[F5]
In Program edit mode, you access them the same way as above.
Sep 09, 2010 | Casio CFX-9850G Plus Calculator
How do i generate random numbers on the casio fx-9860G
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates key presses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
Jul 06, 2010 | Casio CFX-9850G Plus Calculator
Generating radom itegers
In the paragraph above, the bold text in square brackets indicates keypresses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
Ran#×6
Int(Ran#×6)
Int(Ran#×6)+1
Mar 03, 2010 | Casio FX-9860G Graphic Calculator
STAT DIST BINMAL
Press MENU after turning the calculator ON
Use the navigation keys to highlight STAT and press ENTER/EXE
The TAB above the F4 key is DIST
Press [F4:Dist] to access the distributions
Press [F5:BINM]
You get the two binomial distributions that are available.
Select the one of interest to you and complete the command.
Nov 19, 2009 | Casio CFX-9850G Plus Calculator
How do you access air filter on a f4 312r
take the tank off( dont brake the fuel lines) take the air box off turn upside down you will find a slot for the air filter. hope that helps a bit
Aug 12, 2009 | 2006 MV Agusta F4 1000 S
Fn F4 Not working
try ur on screen keyboard.
start,al programs,accessories,accessability,on screen keyboard.
if any keyboard buttons are broke u can still use the functions with the on screen keyboard.
on one of my laptops the enter and del keys dont work so I use the on screen keyboard when I need the function of those keys.
Jan 08, 2009 | HP Pavilion dv1000 Notebook
Ingenico iSC250 Payment Terminal Logo
70 people viewed this question
Top Ingenico Computers & Internet Experts
Scott Fair
Scott Fair
David Payne
David Payne
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
