Question about Amtrol WX-203 Well-X-Trol Stand Well Water Tank, 32 Gal
Loud banging noise Amtrol WX-203
Banging noise when washing machine fills with water and on rinse cycle
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Either solenoid valve is closing or there is a large water hammer occurring
Posted on May 29, 2017
Baxi duotecHEa 40kw combi boiler made loud banging noises for 2 or 3 minutes then stopped. What might have been the problem
the banging is the water boiling/overheating Check the pump is working by undoing the large screw on the front of pump and gently putting a soft stick into the space behind to check that the rotor/impellor is turning. take care to catch the water which drips from the screw hole
Feb 02, 2016 | Water Heaters
Water not going into well water tank
Water that goes in to this tank comes straight from pump, check the foot valve on your well might be bleed water back into well. Also check the air bladder on the tank. Make sure it has proper inflation
Aug 23, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
My AMTROL water well tank is copying the pressure of the prussure switch
Sand the points on the pressure switch
Replace pressure switch
http://www.amazon.com/dp/B000BQSERE/?tag=waterheaterti-20
Test you are getting 240Volt to pressure switch
Turn breaker fully off and then fully back on
Replace control box or replace start capacitor:
http://www.amazon.com/dp/B0060C7GFO/?tag=waterheaterti-20
Drain tank, and replace the air valve
http://www.amazon.com/dp/B000BQYKJK/?tag=waterheaterti-20
Gene
Aug 22, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Water came out of air valve when I went to check pressure
Tank is waterlogged.
Drain tank, install new air release valve
Sep 17, 2013 | Amtrol WX-203 Well-X-Trol Stand Well Water...
I HAVE A 50 GALLON 5YR OLD RICHMOND HOT WATER TANK SOMETIMES YOU TURN ON HOT WATER AND IT RUNS FINE.THEN ALLOF A SUDDEN THE WATER STOPS AND PIPES BANG.WE HAVE 44PSI COMING IN FROM CITY
What you're describing is "water hammer". This problem, left unchecked, can cause big problems for your home's plumbing. Water hammer is result of quickly shutting off the flow of water in your home. The faster the rate of water flowing when it is rapidly shut off can result in very loud banging. The banging is caused by the pipes shaking in the walls, ceilings and any place they aren't secured. This repeated shaking causes soldered and glued joints to weaken and eventually fail. The most common sources for water hammer are toilets and wash machines, but even quickly shutting off a faucet can cause it too.
An short article about water hammer is here. Below is a link to images of products designed to arrest water hammer and associated noise.
Please rate this reply - I hope this helps!
Dec 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Amtrol WX-203 Well-X-Trol Stand Well Water Tank, 32 Gal Logo
82 people viewed this question
Top Amtrol Water Heaters Experts
Andrew Bugbee
Gil Shultz
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
