Question about Zebra Office Equipment & Supplies
Error state: 7 on zebra printer
Shows a red light
otacon
  • 1944 Answers
SOURCE: Zebra Z4M printer error
Did you try disconnecting it from the power for a few hours?
Posted on Mar 17, 2008
  • 7 Answers
SOURCE: Zebra TLP 2844 Error Condition
Qusetion, Using USB my TLP2844 detects as a LP2844ps. Weird, huh? Also when I calibrate it the label does not stop at the perferation. When I print half goes on one label and the other half goes on the next label. Someone told me once there was a trick to get it to calibrate correctly. Anyone here know this? When I print a test page, it feed the correct amount of label.
Posted on Aug 03, 2008
gwbm
  • 353 Answers
SOURCE: printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Posted on Feb 27, 2009
  • 124 Answers
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Posted on Jun 15, 2009
  • 341 Answers
SOURCE: Printer error ... zebra lp 2844 thermal printer
Check your printer folder to see if there is more than one printer installed on your computer and that the Zebra has a check mark next to it making it the default printer.If everything seems o.k. I would then suggest uninstalling the printer software and reinstalling it. Sometimes a file gets corrupted or with windows (I am assuming your using windows) you never know.
Posted on Jun 29, 2009
Lp2844 sound is coming from printer while printing
Green light red
I've a Zebra LP2824 printer , It gives me the Green-Red error .. And the manual guide told me that's a problem with flash programming .. What can I do to solve it ??
Feb 12, 2016 | Zebra LP 2844 Thermal Printer
What is the cause of supplies blinking red color
The printer it is in error state? Any other LED it's blinking or lighted? Do you have any message on display? Please verify if the supplies are on the correct path. Do you use adhesive labels? Verify if there is any label (or pice of label) stiked on the media sensor. You can locate the media sensor using the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
Apr 24, 2014 | Zebra 105Se Thermal Printer
Why zebra printer supplies panel blink red light
Green light red
I would re-calibrate the printer and see if that helps, usually the quickest and correct means to fix ya !
Calibrate Zebra Desktop Printer
Oct 05, 2013 | Zebra Eltron LP 2824 Thermal Printer
I have a Zebra GK420t Alternately Flashing Red and Green light error message. How do i clear this.
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
Jul 25, 2011 | Zebra GK420t thermal transfer and thermal...
What driver can I download to use Zebra 2844 printer with Windows 7
You can use the free drivers from Seagull Scientific:
http://www.seagullscientific.com/aspx/thermal_95.aspx
Good luck, and come back with a testimonial if helped :)
Dec 11, 2009 | Zebra Eltron TLP 2844 Thermal Label...
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
These 2 links will help you troubleshoot the problem:
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dec 04, 2007 | Zebra LP 2844 Thermal Printer
16 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
