Question about Yaesu FT-8900R Nifty Manual
FT-8900 FT8900R left side 440Mhz not working, all other frequencies are working
    Sergeant:
  • 435 Answers
Sounds like the diplexer went bad
Posted on Feb 11, 2015
3 Suggested Answers
  • 3287 Answers
SOURCE: I have a FT-8900 and want to be able to open the
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Posted on Sep 18, 2009
LEHenson
  • 18 Answers
While a double sideband (AM) has been done on this model, it is NOT Legal nor a good quality radio for AM = poor performance!
AE6JI Larry LEHenson@msn.com 73;s
Posted on Jan 09, 2015
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
Unblock code for 8900
Hi, if your phone says Invalid SIM card and there are unlocking attempts left, it's possible to solve this problem for BlackBerry 8900 on Fastgsm.com.
Apr 25, 2013 | RIM Blackberry Curve 8900 Smartphone
Yaesu FT-8900 will not power up
You've prbably answered your query yourself.
Having said that, try joining yahoo group specifically for the FT-8900, they will have more info for you.
Cheers,
Peter
Mar 02, 2013 | Yaesu Radio Communications
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
Feb 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
WHAT IS CYLINDER HEAD BOLT TORQUE ON A 1988 JEEP CHEROKEE LTD. 4.0?
Torque settings are 110 ft LBS for nine of the ten bolts one bolt is 100 ft LBS /#1 Tighten all bolts in sequence 1 to 10 at 22 ft LBS #2 tighten all bolts 1 to 10 at 45 ft LBS #3 tighten all bolts 1 to 6 at 110 ft LBS #4 bolt #7 at 100 ft LBS #5 BOLT 8 TO 10 AT 110 FT LBS . HEAD TIGHTEN SEQUENCE - standing at front of car bolts down left side are 8/4/1/5/9 bolts down right side are 7/3/2/6/10. left side meaning distributor side.
Oct 07, 2010 | 1988 Jeep Cherokee
Just want to retorque the head bolts hopeing to get lucky and solve a minor head gasket leak but dont know the specs
Torque settings are 110 ft LBS for nine of the ten bolts one bolt is 100 ft LBS /#1 Tighten all bolts in sequence 1 to 10 at 22 ft LBS #2 tighten all bolts 1 to 10 at 45 ft LBS #3 tighten all bolts 1 to 6 at 110 ft LBS #4 bolt #7 at 100 ft LBS #5 BOLT 8 TO 10 AT 110 FT LBS . HEAD TIGHTEN SEQUENCE - standing at front of car bolts down left side are 8/4/1/5/9 bolts down right side are 7/3/2/6/10. left side meaning distributor side. A four cylinder engine has ten (10) bolts. A six cylinder has fourteen (14) bolts.
Feb 16, 2010 | 1998 Jeep Cherokee
Red light flashing on ice control panel in freezer section of my Whirlpool gold GS6NHAXVT02. I have the setting on ''on''.
The red light is supposed to flash. The number and frequency of flashes is a diagnostic tool we use to determine what is wrong if the icemaker is not working. If your icemaker is not working, count how many flashes before it rests, and let us know. Good Luck, Appliance Specialists
Jan 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Oct 18, 2009 | 1994 Jeep Grand Cherokee
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
Sep 05, 2009 | Yaesu Radio Communications
Yaesu FT-8900R Nifty Manual Logo
90 people viewed this question
Top Yaesu Radio Communications Experts
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
