Question about Whirlpool LER5636P Electric Dryer
Won't work at all,
My husband just used my dryer 6 hours ago, no problem. this morning i loaded in my kids' clothes. When I turned around to close it, my fast moving 1 year (25lb) son was standing on the door bouncing. I immediately took him off....door seemed fine. But then dryer would not turn on. I did what the manual said...lint trap was clean, plugged up, flip breakers, duct clear, switch on the door intact. Could my son's weigh and movement actually affected the dryer???????????
Please help.
THANKS!!!
  • Anonymous Nov 23, 2007
    same problem
  • asking Dec 27, 2007
    My dryer will not do anything and it only a two years old. The light on the inside will not even come on. I have check the breaker and the plug, but nothing. The small switch inside the door appears to be really loose. Please help.
  • 709 Answers
Hi Lanil,
The only things that will not allow the dryer to start are the following:
  1. I know you said you checked the breakers, but they could be the cause.
  2. The Child bouncing on the doorcould have broken the stub stub that pushes the door switch in.
  3. You may need to firmly press the Start switch.
  4. The dryer need to be plugged in, I know you checked it.
These are the four main things. Since the child bounced on the door, the trouble is most likely with the door switch. Try to use a stick or something to simulate the door closing and activate the switch and push the start button. If this starts the Dryer, and closing the door firmly does not, then the switches position or doors prod that pokes the switch, is not lined up or failiing to fully activate the door switch.
Posted on Nov 03, 2007
Dryer worked for the 1st and 2nd load of clothes. Went to put 3rd load dryer wouldn't work. I checked to see if door was closed properly,and dryer turned on. I also had my husband to check our circuit...
it might be a partially blocked vent that causes the dryer to overheat over a period of use. trips the hi temp limit switch/thermostat. did it cool down and start working, or is this permanent.
Mar 27, 2015 | Maytag Dryers
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
The vents have been cleared & I still have a buildup of moisture which won't let the clothes dry.
Most likely tour blower is slipping. It might be tossing out air but not enough. These dryers are notorius for having bad blower wheels.
To get into it kill the power and raise the top using a putty knife to release the top clips then get the front off and inspect the filter housing for lint. Their will be a big ball of lint. Grab the blower wheel and wiggle. If it is loose you will be able to tell.Hear is my crappy phone video:
Mar 27, 2013 | Amana DLE330RAW Electric Dryer
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Since a month ago our dryer takes a long time to finish a load, A load which used to take 45 minutes to finish now takes close to 2 hours to finish.
check all of your duct work clean it out make sure there is no lint in the duct work going from the dryer to the wall also check the duct work going from the wall to the outside of the house
Dec 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Dryer drum won't turn. It has power, the door is shut tight
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Amana NED7200TW Electric Dryer
My husband included a pen with his clothes. There is black ink all over the inside of the dryer. suggestions?
Shoot your husband.
Just kidding. Most of the ink can be cleaned with alcohol. If it doesn't then try some ink remover solutions or use lemon extract. You may even want to soak a cloth in lemon extract and place it in the dryer in tumble only cycle to let the dryer do some of the work.
Hope this helps. Make your husband do all the work!
Good luck.
May 17, 2009 | Dryers
Dryer won't turn on for 2nd load
A couple of things is to make sure you have 110v at the recepticle, if you do then it's with in the dryer. It could be the door switch wont close, thermal over load won't reset in your motor(if it got hot enough to open, you said it had been in use) , broken belt switch if your dryer has one, or even the thermal fuse (in series with L-1) opened up. Ohm out the door switch in the closed position, it should read 0 ohms, Same with the thermal fuse, should read 0 ohms, not an open read.Good Luck..MJE
Mar 25, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
