Question about Fisher and Paykel DE09 Dryer
Felt from inside come off do i need to put back
Overheats and keeps tripping dedicated breaker in house, venting and inside back panel vacuumed out.
If your dryer has a sensor it may have gone bad. Try using timed dry instead of auto dry.
Nov 09, 2012 | Dryers
How to install belt 4-215-492-01
Take off the felt and the platter. Take some lint free cloth and rubbing alcohol and rub down the pulley. You can also use compressed air to dry it off. Also use the same method to clean and dry the underside of the platter. Put the belt around the ridge on the underside of the platter. Put the platter back on the turntable. Reach inside the access window on the platter and grab the belt. Hook the belt around the pulley. Rotate the platter to make sure it won't fall off. Put the felt back on and you are ready to go!
Jul 03, 2012 | Sony PS-LX250H Turntable
How to repair a sticky/jammed singer heavy duty 4423
Put a felt spool pin holder (an extra one comes with machine and it's either red or white felt with a circle cut out of it in the center)...remove bobbin, set felt circle in bobbin case to keep bobbin from wiggling. The back and forth motion is knocking the thread out causing it to lay flat against top of the bobbin when you start machine, but felt puts bobbin in correct position! Make sure thread falls into tension slots and carefully pull thread back to left of silver piece (stitch finger). Pull up your bobbin thread. Put in new needle since "bird nesting" or jam may have bent the one previously used. Now it should purr like a kitten...smooth sailing! This is how I fixed my Singer Heavy Duty 4423 when I realized the problem is that the bobbin case is a bit wide and felt takes up slack, raising bobbin also to keep bobbin thread moving smoothly through so it doesn't jump out of tension and rest on top of bobbin!!! Works now!
Jimmy
Mar 09, 2012 | Sewing Machines
Need to replace front felt seal. how do you do that?
If the front felt seal is cut or worn out there is probably some thing else wrong too so while you have it apart check the 2 supports that hold up the front of the drum from the bottom at about the 4:30 and 7:30 positions. For access to the felt: unplug the machine - Pop up the top from the front with a slot screwdriver - inside the front at the top corners there will be one screw on each side, remove them and the front will pull forward and lift of 2 hooks at the bottom - There will be wires connected to the door switch, mark and disconnect them before you pull the front away and break the switch - then you can remove the front support the big round thing, the felt is glued to the inside of this, and the supports are on the back side of this - look under the drum and see where the belt is connected to the drum- motor and tensioner, remember how it goes before you loosen it !!! Pick upward on the front of the drum and take it out of the cabinet. Put a few drops of sewing machine oil on the 2 roller supports on the backwall - spin them to make sure they are smooth and not wobbly - if they are replace them - the new seal comes with a tube of glue, remove the old one (watching how it goes back on) clean the metal and glue the new one on, check the front supports, put a few drop of oil on the belt tensioner and reassemble Cross your fingers
Nov 13, 2011 | Amana DLE330RAW Electric Dryer
I felt off my bike and the turn light is hanging out just from the wires the hole indicator its ok but i need to put it back how i do it? just i need to cut the cable and put the indicator in to the...
there should be no need to cut wiring ,just follow the wires away from the light unit and you will find a connector thet you can unplug to do the repair work. hope this helps
Sep 06, 2011 | 2005 kawasaki Eliminator 125
Need to put door back together on 68 mustang convertible owner took door apart i have all pieces
this will require alot of time. if you have another door with the guts inside of it i would suggest you take the door panel off and look at that. make sure the wing window goes in first. make sure the window felts are good. leave everything loose before you tighten anything. make sure you take off the felt weather stripping on the top of the door or you will have a hard time putting the door glass in. if you need pictures e-mail me at jandjautoworks@bellsouth.net
Jul 05, 2010 | Cars & Trucks
GE DPSR483EA Electric Dryer was making a scraping sound when operating, now a felt like belt has come out on the inside of the dryer. what do i do? Kris Long
The problem is something got between the drum and the felt seal between the drum and the front of the machine. You will have to pull the front off and find out what caused the felt to come out and then put the felt back in place and put the front back on.
Mar 18, 2010 | GE DPSR483EA Electric Dryer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes get lodged between dryer barrel and dryer frame
you need a new rear bearing kit and a new top front felt yes this is something you cand yourself. Frist unplug the dryer, with a stiff putty knife releace the clips on each side of the top at front to pop open the top. next on the inside of the front cover on each side is a philips head screw remove both screws ( I find it easier to use a #2 square head for this ) now remove the front panell diconect the door switch.now reach under the dryer drum behind the motor and release the belt by removing the tention on the idler pulley and slipping the belt off the motor shaft (you may be able to do this better fromt the rear of the dryer. there is an access panell remove the two screws and you can see the belt and idler pulley ) now using the belt in one hand and the front of the drum in the other lift up on the rear of the drum ( you are lifting the bearing out of the scocket you will feel it pop out ) now slid the drum out of the cabnet. Now you can repace the bearing put a piece of duct tape over the clip on back center of the dryer ( on the outside ) now remove the two 5/16 screws holding the bearing cup on remove the tape from the clip put ne clip on tape in place set new steel ball in cup i put a dab of the greace supplyed in the kit to hold it in put cup on new bracket. set in place and put screws in you may have to reach around the back to line up the clip teghten screws snug. now in the center of the drum is the bearing on the inside are three philips head screws remove all three some timse you can use a #2 square headi lossen all the screws frist almost completly the remove them one at a time or you will have to hold the bearing with one hand to keep it from spinning. Putting the new bearing on you have to put the screw in one hole hold it with one hand and line the bearing up with the other or get some one to leand you a helping hand makes it alot easier.tighten all three screws good and tight now reinstall dryer drum besure to seat the bearing in the bearing cup again you will feel it pop in put the belt back around the drum. Now on the dryer front you will see the felt support the fron of the drum glides on pull it off just the top felt only with a putty knife clean off as much of the old felt as possable. Apply a genurious amount of the glue provided in the kit to the new felt i always put a good line of glue on the dryer front also press the new felt to the front (be sure if the new felt has plastic glides the overhang should be toward the front not the drum if the new felt does not have these glides you don't have to worrie) put dryer front back on when putting the drum back on the top felt you may need to hold the new felt to keep it from moving. reconect door switch put the two screws back in the front. now go back to the back and putthe belt back on the motor pull the idler to tighten the spring put belt around motor shaft and ease pulley back to belt. Put access cover back on and secure. close the top plug it and test don't let dryer run long just a few seconds I like to let the dryer set 24 hour befor putting back to use to give the glue time to set.
Nov 23, 2008 | Frigidaire FEQ332E Electric Dryer
Posted this question re replacing the felt on the dryer (causing stains)
You pretty much need to take the dryer all the way apart in order to get to replace the felt.  I pulled the drum out and took my time cleaning off all the old felt and glue residue before gluing the new felt guides on and putting the dryer back together.  I found details and parts to order at repairclinic.com
Jul 14, 2008 | Frigidaire FWSB5700DS Top Load Washer
Fisher and Paykel DE09 Dryer Logo
27 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
