Question about Prince Fusion Table Tennis Table
Need two more brackets - Prince Fusion Table Tennis Table
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
I need to mount a 1968 chevy altenator
try rockauto.com and just get the brackets u need
Jun 13, 2012 | Cars & Trucks
Bottom bracket need replaced. needs a new crank set. what size if the bottom bracket and what size crank set is recommended, or does the bottom bracket need to come out to find the size. bought the...
impossible to tell you without knowing the bike brand and model and year, although you have provided that 1999.
If you take into a bike shop, which is the usual place to purchase the parts you need, they will be able to tell you what size Bottom Bracket will fit your bike, also what options you will have for replacement cranks and bottom bracket. This could be a very complicated issue when replacing with parts that are 11-12 years newer, the shop will be best equipped to give you all your options.
Apr 07, 2011 | Cycling
Radio width is about 6 inches. Bracket that holds
I use two L brackets myself, you can get them at any hardware store.......hope this was helpful..
Apr 24, 2010 | Raytheon VHF 53 CB Radio
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • Mar 28, 2009 | 2004 Chevrolet Silverado
    Lee spring bracket for a Ford F150
    You are going to have to go to Ford for this part.Shouldn't be to expensive. They will probably have to order the part for you.
    Mar 18, 2009 | 1992 Ford F150 SuperCab
    Cd player bracket
    Come on all you have to do is get one from the junk yard
    Nov 01, 2008 | 2000 Lincoln LS
    Water pump assembly and power steerin pump brackets
    need to know year? engine size?what accesories equipped? a/c power steer smog pump etc.
    Aug 26, 2008 | 1989 Dodge Ramcharger
    Prince Fusion Table Tennis Table Logo
    48 people viewed this question
    Top Prince Sport & Outdoor - Others Experts
    Are you a Prince Sport and Outdoor - Other Expert? Answer questions, earn points and help others
