Question about LG Electronics Unlocked Optimus G Slate V909 8.9" 4G Tablet PC, GSM, nVIDIA Tegra 2 T250 Dual-Core 1GHz Processor, 1GB RAM android 3.1
LG V909 freezes on home screen - LG Electronics Unlocked Optimus G Slate V909 8.9" 4G Tablet PC, GSM, nVIDIA Tegra 2 T250 Dual-Core 1GHz Processor, 1GB RAM android 3.1
Why won't apple iPad mini play MP3 songs or video?
If it crashes like that, I would delete the app and re-download it. If not, I would restart the device by pushing both the home button and the power button.
Apr 14, 2016 | Apple iPad Mini
When I reset my lg vslate tablet now the touch screen doesnt work
Attach to power charger. Try hard shut down then try reboot all while connected. Then at that point you should see your keyboard again once o/s is back up.
Feb 11, 2015 | LG Electronics Unlocked Optimus G Slate...
I have a lg g pad 7.0 and it keeps freezing on me how do i get it to stop freezing up?
Sounds like a software issue. If possible see if there is a update for the device. That could help with the freezing problem.
Dec 02, 2014 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
Phone does not recognize sd card
Make sure that the SD card itself is not bad.
If you know the card works, try to see if the device will let you reformat the card in the device, if it does not see the card at all you may have to reformat it in a computer - doing in the device is the preferred method though. If you do need to do it in a computer you will need to find out if the card should be in the FAT32 or NTFS format.
NOTE WHEN YOU REFORMAT THE CARD EVERYTHING ON IT WILL BE WIPED AWAY - COPY EVERYTHING ON THE CARD YOU WISH TO SAVE TO YOUR COMPUTER AND THEN COPY IT BACK ONTO THE CARD AFTERWARDS.
You can also try posting your question in a fan based forum such as this to get more detailed answers
http://www.howardforums.com/forumdisplay.php/621-LG
Have a magical Day
K
Jul 25, 2014 | LG Electronics Unlocked Optimus G Slate...
Replaced digitizer now black screen only
If the LCD was working before replacement, the most likely suspect is a loose cable connection. It is also easy to crimp those tiny flat cables, or to break the locking mechanism so the cable can work its way loose. Sounds like you booted to a black screen after repair, so I would walk back through it and double check every connection, then look at all cables closely in bright light and with a magnifying glass, to be sure nothing sustained damage (twist, crimp, etc.). Remember to check the power cable to the LCD, as well. No power, no backlight, no video.
Mar 22, 2014 | LG Electronics Unlocked Optimus G Slate...
Lgv909 can not connect to wireless
Its running on a 5ghz and the modem or router is 2.5ghz. Upgrade your modem or router that it has a 5ghz and a 2.5ghz option
Dec 04, 2013 | LG Optimus V909 Android
Lg v909 tablet keeps rebooting
My LG v909 is complaining of 'too many pattern attempts'. Its asking for my gmail login credentials however it has no internet though a data sim card has been inserted. Anytime I insert/remove the sim card the desktop shows for only 5seconds and reboots. Can anybody help me please ?
Jan 24, 2013 | LG Optimus V909 Android
Google Play Store constantly Force Closes, how do I fix it?
Even still to this day, it happens.
I've figured a temporary solution to fix this issue.
1. Go to settings > apps > manage apps and make sure you are under all apps tab.
2. Find Google play store and force close it. Then select uninstall updates.
3. Go back and scroll down to find Market Updater?... I think is what it is called and select force close.
From now on, only use the Market. The Google Play Store icon may disappear from the apps/app drawer... which is exactly what you want.
Problem solved.
If it ever happens again and Play Store comes up again, just repeat the process. As I said, I believe this fix is only TEMPORARY.
Nov 09, 2012 | LG Optimus V909 Android
LG Electronics Unlocked Optimus G Slate V909 8.9" 4G Tablet PC, GSM, nVIDIA Tegra 2 T250 Dual-Core 1GHz Processor, 1GB RAM android 3.1 Logo
18 people viewed this question
Top LG Tablets & eReaders Experts
Jax Planet
Jax Planet
Andrew Taylor
Andrew Taylor
bigdawg7299
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
