Question about RCA RS2030 System
Rca rs2030 cable to subwoffer
I have a system a rca rs2030 and need the male to male conecctor to connect them,both seem to have 9 pins
2 Suggested Answers
jrox55
  • 66 Answers
SOURCE: How to connect an Xbox 360 to an RCA RTD205 System?
you can turn every thing into surrond sound. all your visual componants, i.e. x-box, cable, dvd player and so on. connect directly to your tv, right? if so go to your local eltronics store and get youself an optical cable, typically $50.00 or so depends on the length. Go home with that cable connect it to the optical out on your tv and optical in on your reciever, (stereo) and bam all componants are now linked to your surroun sound. Dont forget to post your satisfaction. Be sure you have optical in and out before you go buy this wire. For god sake do not kink this wire either or you will have to buy a new. There is glass inside of optical wires, that transmits the light that the sound travels on.
Posted on Feb 26, 2010
Need a manual for a RCA DVD micro system an rs2030
homeaudio.englishmanuals.com/stereo_system/.../rs2030-453786.html
Sep 14, 2014 | RCA Audio Players & Recorders
Whats the name of the conecting cable from jcv subwoffer speaker ro jvc reciever rx 5042
The cable you need to connect the subwoofer to the receiver is a Male RCA to Male RCA, Mono shielded cable, the length can be chosen according to your needs.
Good Luck
Oct 30, 2013 | Audio Players & Recorders
Where can I purchase the cable to connect my dvd player to my tv..I need the one that has a pin on one end and a white/yellow on the other
Hello hyegee -- You could probably get one directly from the manufacturer at a way over the top price. The cheapest and easiest thing to do is to get two generic cables at any store that carries electronic accessories.
For audio you need a stereo 3.5 mm male to stereo RCA jacks male cable. For video you need a simple 3.5 mm video male to RCA jack male video.
Here is the graphic from the user manual. Yours new cables would hook up the same but just be two instead of one cable:
Good Luck and thanks for using Fix Ya
Mikeywaf
Mar 20, 2011 | Coby TF-DVD7307 Portable DVD Player
How can i hook up xm receiver to unit
hi,
you can connect the XM receiver to you player. for that you need a cable (STEREO MALE TO RCA MALE CABLE). its one end will looks as headphone pin and the other end 2 RCA pins.
connect the headphone pin to you XM receiver's earphone out and the other end (2 RCA) to the AUX IN 2 (AUDIO L/R)(on the rare pannel) of ur player.
select the AUX 2 input pressing the FUNCTION button on your player.
or
purchase a STEREO MALE to STEREO MALE cable and connect its one end to the earphone out of XM radio and the other end to the AUX 1 input of you player (on the frond pannel)
select AUX 1 by pressing FUNCTION button
ok
Jan 13, 2011 | Samsung HT-X50 System
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Spherex IR cable replacement
After looking for this cable and talking to some of my friends - I was able to determine what type of cable it is. it is called a Mini din 9 pin male to male.
Molded Cable, Mini din 9 Pin Male to Male, 6.0 feetI bought from this guy - http://www.stockcable.com/products.php?pid=17&detail=true#thumb
hopefully you fellas from across the pond can find a place to purchase it.
Aug 03, 2008 | Spherex Xbox 5.1 Surround Sound System...
Cable
WHAT IS THE NAME OF THE CORD THAT RUNS FROM THE RECEIVER WERE IT SAYS SUBWOOFER TO THE BACK OF THE SUBWOOER?
Mar 02, 2008 | RCA RS2030 System
RCA RS2030 System Logo
57 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
