Question about Cameras
Camera will focus take photo but on playback & download there is no image only black? For a while a light bump would facilitate a recorded image but no longer.
    Brigadier General:
  • 8,619 Answers
Hi
This is caused by a stuck shutter inside your lens. When the shutter is stuck closed no light can reach the image sensor and the result is a black image on the screen and on photos.
You can try GENTLY tapping the camera on a hard surface to free the stuck shutter, but be extremely cautious because this can easily further damage the camera. If that does not work you will have to get the unit serviced (I believe it’s the CCD sensor that should be repaired or replaced). If it’s a Nikon Camera then it qualifies for the service advisory @ http://www.nikonusa.com/email_images/nik... they should repair it free of cost. Send it to them today.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 19, 2009
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
My lumix camera in playback mode has on screen tv
If you can get into the menu and find "reset" you could return the camera to factory settings.
Feb 21, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Recorded image has horizontal lines/brown coloring
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
For the downloading issue, please see:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Apr 12, 2009 | Canon PowerShot A85 Digital Camera
Black Photos
are you using the camera in manual mode (M)? try putting the camera in AUTO mode (the green icon)
Apr 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Sony cybershot DSC-T2 has a blue screen on playback
Dont worry, you can recover photos from camera with photo recovery software, recommended asoftech photo recovery as it helped me before. Download the software from
Camera Picture Recovery Software
Here's a good tutorial you can follow
Restore images from Camera
Dec 26, 2008 | Sony Cyber-shot DSC-T2 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Samsungscd23/blank viewscreen for photo memory stick
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Aug 01, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Cameras Logo
23 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
