Question about Polti Vaporetto 2400 Canister Steam Vacuum
Fails to switch on - Polti Vaporetto 2400 Canister Steam Vacuum
No power to switch. ts there a reset button?
Check the power plug cord, might be bent so often that the internal wire)s) are broken. You can cutoff old plug and replace with new one.
Jun 08, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why does my vax rapide not turn on?
The only easy answer would be a bad connection at the plugin receptacle, a bad receptacle, open circuit-breaker or fuse at your electrical panel. Assuming these have all been verified as working
(check by plugging it into a different circuit in the house. If it works then the problem is at the original receptacle and not the vacuum). Then the electrical wiring and components of the vacuum must be checked. This is normally done by a qualified serviceman.
There is no rest button that I am aware of. Make sure the switch is pressed on firmly. The most common problem is a faulty switch, however there are several other possibilities. The vacuum has a simple overload switch that turns off when it is overloaded. Once it has cooled, it will close in again allowing it to work again. This could fail open but it is rare unless it has operated many times previous to not starting now. A more common problem is a broken or open wire. This usually happens at connections and may be burnt open because of a loose connection. Sometimes the start switch on the motor fails or the motor itself fails. Unless you are knowledgeable with working on electrical circuitry the repair should be done by a qualified repairman.
May 15, 2014 | Vacuums
Dyson DC27 brush drum fails to rotate. Belt is fine.
Dc27 has a motor to spin the brush. It might be the brush bar motor or the power switch to the brush bar motor.
Oct 20, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
When the power button is pressed the vacuum turns on, when the button is released the vacuum turns off
This is a common problem for the dyson DC08 & DC07 vacuums. The switch itself is a little bit weak and after a time just fails. Basically the only proper solution is to have the switch replaced. The switch itself is fairly cheap and is only a 10 minute job to fit. Normally by the time the switch is failing I would recommend replacing the washable filter too. If you live in Australia you can get any related parts from Nelson Vacuums or VacuumSpot.
Hope this is helpful for you.
Jan 24, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson will not switch on
Usual problem is the fuse in the plug. Check the fuse first. If this fails then your problem is either the Switch (Unlikley) or the Motor. Its unlikely the motor would break without warning though. If you have had any burning smells or funny noises recently then its the Motor.
If there are no Smells then im confident its only a case of changing the fuse. Quite common for the fuse to go.
Oct 23, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
Rug brush not turning- pushing reset doesn't engage
inspect the brushroll motor switch for proper operation. these fail frequently. if the main brushroll switch is good, there is also a switch inside the body that activates the brushroll motor when the handle is brought back. that switch could also be bad. if all else fails check the brushroll motor for contenuity. if it has high resistance, the motor is bad
Feb 27, 2010 | Dyson Slim DC18 All Floors HEPA Bagless...
Hi I have Bissell powerforce Vacumm, but I am not able to find the power on/off switch - Ajith
did you look on the base either side. also try above clear base it shouldn`t be hard to locate. if all fails contact bissell.com
Oct 04, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell Healthy Home Agitator Brush Switch
you might have a bad belt ,could be stretched .but if its new i would take it back to where you bought it.it should still be under warranty
Mar 29, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Polti Vaporetto 2400 Canister Steam Vacuum Logo
29 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
