Question about Brother MFC-6890CDW Printer
6890 waste waste ink tank
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
How to clean waste tank on MP730 "waste ink tank
  1. press menu - copy - #
  2. Select TEST MODE.
  3. Select [8] PRINTER TEST in TEST MODE.
  4. Select 3. [EEPROM CLEAR].
  5. select 0. [INK COUNT].
  6. press the [OK] key
  7. press stop to cancell
  8. restart the printer
Oct 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
How to clean waste tank?
The waste ink tank is on the Drum, you have to disassemble the drum to clean and remove the wasted/old ink. Please follow the instruction provided here.. FixYa's Tips on how to remove the waste ink from the waste ink tank (laser printer)
I hope you can follow the simple instructions.
Good luck.
Thanks for using FixYa.
Jun 27, 2010 | Samsung CLP 300 Laser Printer
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Pixma Ip90v waste ink tank full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Dec 16, 2008 | Canon PIXMA iP90v Printer
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
Brother MFC-6890CDW Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
