Question about Hoover U6476-900 WindTunnel Vacuum
Hoover uh70400 switch needs replacing - Hoover U6476-900 WindTunnel Vacuum
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
How to change on/off switch for Hoover model U5753-900
Hi! The on/off switch is located on the handle. To replace the switch, the handle would need to be replaced. Handle 39466088 can be purchased from an authorized service center or by calling Hoover Customer Service at 1-800-944-9200. To replace the internal rocker on/off switch it is recommended taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator Hope this helps!
Jul 30, 2014 | Hoover Vacuums
Hoover Tempo on-off switch
Find a Hoover service center, there is a recall on those switches. They'll replace it for you free of charge!
Apr 19, 2013 | Hoover U5144900 / U5146900 / U5147900...
How to install inside on/off switch on hoover windtunnel bagged sweeper
This switch is subject to a recall. Find a local Hoover service center and have it replaced. Completely Free.(YAY!)
Good Luck!
Aug 21, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover WindTunnel Model # U6445-900. The on/off switch needs to be replaced and I'm not sure what parts are needed to repair it. Thanks Gloria
You can order any parts needed at the below link. This is a parts diagram. The switch kit doesn't have a part number here, but it's the second item on the list.
http://www.fiorijanitorial.com/p-447-hoover-windtunnel-parts-self-propelled-body-u6423-900-u6425-900-u6425-920-u6431-900-u6445-900.aspx
I recommend using the below site to order. It provides a clear picture of the switch kit.
http://www.sweeper-city.com/howiswkit.html
Mar 16, 2011 | Hoover Vacuums
Windtunnel bagless vaccum model uh6000 on/off switch no longer working, must plug/unplug unit to use. Can switch be replaced?
Yes they can be replaced and are relatively easy to fit. In my opinion, Hoover are one of the best vacuum manufacturers when it comes to obtaining spares and you should have no problem getting one. I did a (very quick) search and this switch apparently fits all Windtunnel Hoovers:
If this doesn't look like your switch, I suggest calling the supplier to verify which part you need for your model. If you'd rather get one fitted for you, any competent appliance enginner or an authorised Hoover service centre should be able to obtain and fit the part easily. I wouldn't pay more than $20-25 in total as they take about 5-10 minutes to fit, max.
Nov 04, 2010 | Hoover Vacuums
Hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Oct 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The on off swtich doesn't work on our hoover windtunnel vaccum cleaner. Can it be repaired?
If its just the switch then by all means it can be repaired or replaced. If it needs replacement and the part is not available, you could replace it with a generic switch which may need some modification. Alternatively you can bypass the switch with the wiring and turn the machine on and off at the wall outlet.
Best wishes,
Graemevm
Jun 06, 2009 | Hoover Windtunnel Supreme U5280-900...
Hoover U6476-900 WindTunnel Vacuum Logo
35 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
