Question about VWR Galaxy 14d Centrifuge 37001-296 W 18 Place Rotor micro 814
Centrifuge won't spin up - VWR Galaxy 14d Centrifuge 37001-296 W 18 Place Rotor micro 814
My centrifuge 5702 rotor mentions error 3
The Eppendorf manual states that Error 3 means that there was an anomaly in the speed sensing system. The corrective action is to leave the power on with the centrifuge not spinning for several minutes and the error should clear itself.
If the error persists, then the speed sensor is probably damaged, and the unit will need to be serviced by a qualified technician.
Apr 16, 2013 | Eppendorf North America Eppendorf 5702...
What does a centrifuge do?
It basically spins very fast and is used to separate denser elements from less dense ones. When spun, the lighter elements raise and the heavier ones go to the bottom
Jan 13, 2013 | Science & Laboratory
Starter just whines when i hit the start button on my xl1200c 2004
Hi Wendywendy99, it sounds the like starter drive/clutch has gone south, it has components inside, that when spinning, centrifugal forces cause them to grab or lock into permanently fixed counterparts. The gear only spins one way and locks the other way. If you have one that spins both ways it has failed and needs to be replaced. Please visit the web site below for more help and good luck. Harley Davidson Manuals Mark Workshop
Sep 09, 2012 | Harley Davidson XL 1200 C Sportster Custom...
Amana front load washer hums only
A centrifugal switch to allow the motor to start up on the start winding and once started it opens to take it out of the start winding. The motor has to have voltage applied to the start winding and the run winding at the same time in order for the motor to start. The capacitor is part of the start circuit. When the motor goes to start, the voltage must be applied to the start winding in order for the motor to start or it will just hum. The moment the motor reaches a certain RPM the centrifugal switch opens up to remove the start voltage to the motor and it will remain running on the run winding. The motor will not start up on run voltage alone. It needs both, the start voltage and run voltage.
I think the problem is that the motor is not getting the start voltage supplied to the motor or the start winding has opened up in the motor.
Oct 22, 2011 | Amana NFW7300WW Washer
I have an LG top loading 6.5kg Fuzzy Logic washing machine (T6515TDPT01). It is 3 months old and has worked fine until now. It won't spin the clothes properly. The tumblers in the bottom of the machine...
Contact the vendor!!! I assume it is still under some sort of guarantee/warantee? You can nulify any guarantee if you attempt to fix problem before contacting vendor.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 10, 2011 | LG Washing Machines
The drum won't tumble until you spin it manually and then push the start button
You have a broken centrifugal switch on the motor. The motor needs to be replaced.
Jun 15, 2011 | LG DLE2532W Electric Dryer
8 year old dryer. drum not spinning to tumble the clothes. checked and the belt is ok? What is the next thing to troubleshoot?
Check that the motor is turning. If not turning, is it humming? If humming, then the problem is likely start winding or centrifugal switch failure. Try lubricating centrifugal switch if stuck. If that does not work, replace motor. Be sure to disconnect dryer before working on it. Centrifugal switch assembly is located in the motor frame on the shaft.
Nov 28, 2010 | Whirlpool Dryers
Spin cycle wont ingage after it drains
Probable motor/trans coupling . If it agitates strongly but wont spin , then probable transmission problem . If not agitating also , then coupling problem .
Jul 19, 2009 | Kenmore 22422 Top Load Washer
VWR Galaxy 14d Centrifuge 37001-296 W 18 Place Rotor micro 814 Logo
89 people viewed this question
Top VWR Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a VWR Science and Laboratory Expert? Answer questions, earn points and help others
