Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Delonghi espresso machine leaking water out back
While brewing coffee the water leaks out the back. Only 1/2 cup of coffee is brewed.
3 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: I have a DeLonghi Coffee/Espresso
Hi Kavogel,
Leaks sometimes caused by a detached drain tube or the tub does not drain. There are some ways on how to correct the problem, either you check the sewer drain and restore the connection of the drain tube or the tub. In addition, please follow the steps below on how to determine the cause.
1. Check the tub if it's not drained. Please check the sewer drain.
2. Please check the drain tube if is detached, broken or has obstruction to water flow.
--> to fix it, just restore the connection of the drain tube or tub.
3. It might be a a hydraulic leak in the hydraulic circuit, so you need to identify and eliminate hydraulic leaks.
4. Check the O-ring or poor mechanical seal of the shaft.
--> check also the status of the pump.
5. The inlet and outlet connections are loose. Please tighten the connections.
6. Check if the hex nut of the pressure relief valve or of the filter are loose. Tighten them.
7. The gasket or the O-ring of the pressure relief valve or of the filter are defective. You need to replace the gasket and the O-ring.
--> Please make sure not to change the calibration of the valve.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 17, 2011
mc1bean
  • 3053 Answers
SOURCE: water leaking from bottom of
Hello, cat
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Leak whenever I make a cup of coffee
Please consider the following:
1. Descaling (Machine should be descaled every after 3 months, every 500 brews, every time the machine prompts you to do so..(whichever comes first)..)
2. Lubricate the brew unit / Clean the brew unit with running water
3. Run hot water through the nozzle / Run how water only through the spout (to check clogs)
~ if above mentioned are no good, contact the customer service for the nearest ASC
Oct 15, 2012 | Saeco Magic De Luxe Espresso Machine
Water leaks when in brewing mode
If you are having problems with leaks while brewing, do the following: Under the top lid there is a needle that punches the hole in the k-cup, this needle has an o-ring on it. Move the o-ring about 1/8 to 1/4 down towards the sharp point. This will allow the o-ring to seal against the k- cup.
Dec 25, 2011 | Keurig Elite B40 Coffee Maker
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
How to remove and clean milk out of espresso water tank :-(
NO the tank is just that a tank and you cant get into it to clean....there are many products for cleaning your coffee pot. Some coffee brewing cleaning products are made by Urnex.Buy mixing a half cup (1/2 cup as i assume espresso meaning a small tank the more vinegar you use the more cycles you'll need to remove) of vinegar with the rest water and brew once or twice 2-3 times or until its right to you.
May 12, 2009 | DeLonghi Caffe Figaro BCO110 Espresso &...
Leaks water out overnight
I bet it leaks from the back, right? If it does, it has the same problem as my dad's.
You have a leak in the back of the holding tank. Fill it up, turn it around, without plugging it in, and watch for the water leak. If it's in a spot that you can see, then use some caulking to seal the leak. That should work. If not, it is leaking out from inside the plastic holding tank. Not much you can do but buy a new one.
Mar 01, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
19 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
