Question about Elna Sewing Machines
Where can I find the Mandal for an old portable Elna Sewing machine?
The stich are not looking very normal...
  • Elna Master
  • 1,133 Answers
You could start at sewingpartsonline.com, they have a list of Elna models with manuals and spare parts. You will need to find the model number however, it should be on the right side panel, a little plate with Tavaro SA and a two digit code number. If its a Lotus code might be 15, 25, 35 or 36. Also, if you do have a Lotus, please go to my solutions and find mine regarding winding a bobbin. The Lotus has no tensioner on the bobbin winding so it is critical that you tension the thread by applying your hand or scissors to the top of the thread spool as the thread winds off it and use your finger to nudge the thread so it feeds onto the bobbin nice and evenly. If you bobbin has wound without tension then the thread will be loose and uneven and you will never get a good stitch from it. Also, check that you are clicking the bobbin thread into the tension spring on the bobbin case. I'll attach an image to assist.
Where can I find the Mandal for an old portable El - 24171195-35jrdbew1xs3n1nuzpszf34m-4-0.jpg
Posted on Feb 21, 2015
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
  • 6 Answers
SOURCE: Manual for Elna Contessa 310
www.janomestuff.com
Posted on Sep 18, 2009
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
Tally Girl
  • 1133 Answers
SOURCE: How do I insert the bobbin into an Elna Lotus
Elna bobbins have holes on the top, so wind the bobbin with the holes on the top too. The Lotus bobbin winder doesn't have a tension device, thread just goes through an eyelet. So, place your scissors curved handle on top of your thread spool as it unwinds the thread to ensure the thread then winds onto your bobbin evenly. Also watch the bobbin fill and give the thread a nudge with your finger tip to fill top and bottom as well as the middle part, you want it to wind evenly across the full width of the bobbin. When full, pop bobbin winder back to left, cut thread and pull off the bobbin.
Then place the bobbin into the bobbin holder with the holes on top, and pull the loose thread tail around anti clockwise into the tension device and gently "click" it into the tension spring with the tip of your finger while holding the bobbin still with your other index finger.
You will be able to tell if it is in tension if you then pull the thread and it doesn't come out of the tension spring. It should feel firm with resistance but still release thread to a gentle pull. tally_girl_6.jpg Now thread the top down to the needle and holding the end of the needle thread, hand wind the fly wheel towards you to lower the needle and pull up the bobbin thread. Close the bobbin cover.
Always hold the two thread tails at the back of the sewing area as you start stitching a seam until you have stitched at least 4 or 5 stitches to avoid thread jams.
Lotus is a lovely vintage machine - there is a user group on Yahoo Elna heirlooms where you can find lots of info and pictures shared by members.
Posted on Mar 10, 2011
Can u do normal straight stiching with ovetlocker model 686 elna?
No. A serger is not made to do straight stitching. However, you can accomplish the look of straight stitching as long as it is on the edge of fabric. The serger trims fabric from the edge and encloses the raw edge with thread.
If you want straight stitching, you need a sewing machine. Go to a sewing machine repair shop and ask if they have an inexpensive old mechanical sewing machine...like an old Singer, White, Necchi, Kenmore--the old metal kind.
Jun 20, 2017 | Sewing Machines
I have an Elna Junior Club sewing machine and I am sewing Lycra and using the number 14 stretch stich. It just loops and bunches up underneath even though I have set everything as instructed.
Did you pre-wash the fabric? Sometimes the finish applied at the factory causes problems. Also, be sure to use a ball point needle on knit fabric. Sometimes, using a walking foot, teflon foot, or roller foot will help the fabric move smoother through the machine. It could be that your machine is experiencing a problem with the back-n-forth movement of the stretch stitch. Otherwise, here are more guidelines to review:
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Sewing Spandex Tips
Feb 02, 2017 | Elna Sewing Machines
My elna 7000 sewing machine speed all of a sudden is very slow, does not work in reverse, or does not want to make any stiches? What can be wrong?
Looks like this is a mechanical machine. If so, bet it needs a good cleaning and oiling. The following may be helpful:
It was working now it seems to be frozen the needle part wont move
Definitely get some good quality sewing machine oil. Sounds like the machine has basically seized, including the stitch selectors.
Apr 26, 2016 | Elna Sewing Machines
Elna 3007 reinforces every stitch.
It is in Stretch Stich mode....(SS)
Check your manual to reset in normal mode
Apr 07, 2014 | Elna Sewing Machines
Elna 6200 stuck in bobbin mode but sticking
Is the bobbin winder spindle on top of machine pushed over to the right in winding position? Move it back to left to change back to sewing mode.
Nov 30, 2013 | Elna Sewing Machines
I have an old,old elna portable machine. can,t find model number. I found
try contacting elna customer service and ask them about the
sewing machine
Mar 27, 2013 | Elna Sewing Machines
Machine tension
I downloaded a manual from another site and followed the instructions.
Aug 18, 2008 | Elna Quilter's Dream 6003Q
Satin stich scallops
stitch no. 29 "F "foot 7.0 width 0.4 length tension 2-3
Jan 28, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
103 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
