Question about Soundstream Inteq VR-931NB Car DVD Player - 9.3" Touchscreen LCD
DVD player not working
WArning sign will not allow to watch movies on dvd
Toshiba SD-6100KU2 DVD Player keeps freezing up.
check blu ray dvd for finger prints or scratches. may need to clean the dvd disk with a soft cloth with pure alcohol or metho.
Sep 22, 2016 | Toshiba Televison & Video
I bought 3 disney movies from the us can'play them on my dvd need a code area australian
Of course I cannot condone any solution contrary to any Australian, US, or international law.
Most DVD players offer the option to change the region code...
Please be aware that due to DVD piracy problems, every DVD player manufactured, regardless of who makes it or where it is made, allows a maximum (if at all) of THREE region code changes.
In your circumstance, this would mean that you can change your DVD player region code to region 1 (US), watch your videos, and then change it back to the AU region code...You would then be allowed one more change. If you attempt to change the region code after that, your DVD player would lock out and be turned into a paperweight.
As a "Yank" who has been to Australia (Perth NSW- twice!) I sympathize with your problem- wanting to have these videos forever and not being able to watch them at all....
The only "safe" option that I can offer is to surf the web for a program called DVD-Shrink, or something similar that will allow you to remove the region code from your DVD's, and set it to "region zero"...which will play the DVD anyplace, anytime. DVD-Shrink works as a copy program from a PC DVDR drive and can remove most region codes from a DVD depending on the disc- most is explained in the FAQ.
Please do not allow yourself to be duped into trying an "all regions" download for your DVD PLAYER. Every single one that I have received a reply about, after warning off the "customer" has resulted in a "my player does not work anymore" response!
Mar 02, 2011 | Televison & Video
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
My dvd player not play movies .i was wrighted from computer that movies by nero software
I hope I deciphered this correctly. You'll find that Nero will play the movie but that won't allow a DVD player to do the same. You may be able to watch it on your computer but that's about it. To write a DVD to watch on a DVD player you need extra software and as this encroaches on Piracy I'll leave it at that.
Apr 07, 2010 | JVC TH-M505 System
It's not working. The profanity still comes through when watching a dvd. I tried setting the tv on caption cc2. I think I did that. It did not make a difference.
U can't not stop profanity,if u watch NC17,PG13 or Rated R DVD movies.Captioning CC1,2,3 dosen't effect the DVD movie.It only have captioning on the tv that in tv brocasting shows,not in the DVD movie.If u want no profanity in movies watch PG movies.
Mar 17, 2010 | RCA DRC247N DVD Player
When I try to play a movie, I only see the warning sign on the screen. I can hear the movie playing, but the warning will not go away. This is even when the vehicle is in park. Any ideas what may be wrong?
Bypass Code
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
Aug 18, 2009 | Jensen's VM9312 Car DVD Player
Player won't play certain dvd's
the password is the arrows you have to do forwrd,backward,forward,backward but use the doubke arrow keys. this should work i found the soloution the manual
Mar 12, 2009 | Disney Hannah Montana DVD Player
Dvd color is off
Depending on how it is configured to your TV it could be high contrast with the TV. One thing you might want to try is replacing the video cable if you have a spare. If you are using an RF modulator and watch DVDs on Channel 3, you might want to replace the coax line between the box and the TV set.
Jun 29, 2008 | Panasonic DVD-S35 DVD Player
Soundstream Inteq VR-931NB Car DVD Player - 9.3" Touchscreen LCD Logo
Top Soundstream Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Soundstream Toy Expert? Answer questions, earn points and help others
