Question about Sony Ericsson W910i Cellular Phone
My mobile has stuck
My mobile call and end buttons is not use . there is no response to these button press
    President:
  • 1,952 Answers
CHANGE THIS BOTTEN NOWAY THEN IC IS FAULT
Posted on Jun 19, 2009
Hp w2207h on/off button is stuck
Most monitors just Snap together and just have a few screws in the back. You should be able to just use a screw driver and gently pry apart the case of the monitor where the button is stuck. This should allow the button to pop back up.
If that does not work, you will have to dissemble the monitor, Once disassembled you should see a little board on the inside where the button is on the outside. There will probably be a few screws holding it in. Remove these screws and take the board out. Press each button on the board and see if they "click" if you get a good tactile response from then then we can move on to the next step. If one of them does not give a good tactile response then the button its self is bad.
If all the buttons on the board DO have a good tactile response then, Look at the case were you just removed that board from. You should see a piece of plastic that has all the buttons attached to it. Do you see one that is pop'd up? If so then press this back down. If it feels grimy like it has something preventing it from moving smoothly you may want to take some 70% alcohol and clean the button area. This should solve your issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Apr 08, 2014 | Computers & Internet
How do I go about setting up a pin-code for my samsung star GTs 5233A as I dont have a users manual
*2767*688# remove USER CODE and SIMLOCK
Unlocking:
We are not responsible to accident with your phone.
You trying this codes only at your own risk!
We are not admit any explanation.
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
phone unlock : *2767*782257378#
Feb 15, 2012 | Cell Phones
Model T41361, display is stuck with "12-24 HR". No response to any button press
it probably one of your watch button is stuck that is why you cannot use any of the buttons, try to bring it to timex watch service center. because they have the tools to open and close it. and tell them to lubricate all the buttons so that they will not stuck again. i hope i had been helped you.
Aug 11, 2011 | Timex T41361 Watch
My HTC HD2 is stuck on the homescreen, It want let me get in the start menu to get in settings to do a factor hard reset
You can do factory hard reset for HTC HD2 even when it is turned off. But it will erase all contacts,downloaded contents and user informations. The phone settings will be reset to factory default.
These are the steps to hard reset HTC HD2.
  1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it.
  2. Release the VOLUME UP and VOLUME DOWN buttons.
  3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Mar 06, 2011 | T-Mobile Cell Phones
Says to reset color ink tank. put a new one in and says same. reset many times nothing happens
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Feb 21, 2011 | Canon PIXMA iP90 Mobile Printer
If i turn on my celphone the bootup shows only touch pro 2 then does not load
this is a quick fix but unfortunatlly all the info will be lost on the phone. its called a hard button reset this helps when its stuck on the main screen, bootscreen or in this case the touch pro 2 screen. i found this info at http://forums.t-mobile.com/t5/T-Mobile-Touch-Pro2/touch-pro-2-stuck-in-boot-screen/m-p/186641#M1996.
: While the TP2 is turned off, press and hold down the Talk/Send key and the End key and press the Power/On key simultaneously. A screen that comes up has a warning, then tells you to press the Volume Up button to reset to factory fresh. Try it, if you haven't yet.
Message Edited by MCbrian on 09-14-2009 10:47 PM
this will work 100%!!! i hope this helps!!
Dec 24, 2010 | Cell Phones
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
No power When I press power button.- Battery is full
Try changing ur battery if it doesnt help then do this
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update
other wise check xda forums for software dead HTC http://forum.xda-developers.com/
pls do rate me if i fixed ur problem
Feb 24, 2009 | HTC Touch P3450 Smartphone
first take out the battery for like 1 min and then follow the procedure its a software issue
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
Jan 23, 2009 | HTC Touch Dual Slider Smartphone
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Sony Ericsson W910i Cellular Phone Logo
66 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
